Go to Post The point of FRC (in my opinions) is to teach the kids that might have no skills, new skills. - dirtbikerxz [more]
Unread 18-12-2009, 16:48
Patriot3017 Patriot3017 is offline
FTC #3017
Patriot3017 is an unknown quantity at this point
Help FTC Motor Connection with Tube
My team is trying to figure how to connect a 12V DC motor to 220 mm tetrix tubes listed below so that it would stay attatched and still rotate
http://parts.ftcrobots.com/store/det...&c=1&t=0&l= 0
can someone please share their ideas/opinions about this? thank you in advance
Unread 18-12-2009, 18:21
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: Help FTC Motor Connection with Tube
i dont understand your issue. why have you already tried that isnt working?
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 18-12-2009, 18:26
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
If you are using the tube as a drive shaft for the 12-volt motor my advice would be to give up and try something else. The ends for the tubes aren't really suited to torsional forces. We've attached them to the servos with some success, but not the big motors.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 18-12-2009, 19:06
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
You might try a chain drive on those tubes. I saw teams use the tubes as rollers quite effectively at the Richmond event last weekend.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 18-12-2009, 19:55
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
You can drill out the threads on the motor hub and then bolt the motor hub directly to the tube clamp.
Unread 18-12-2009, 20:22
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Patriot,
If you are only going to require the tube to move a few turns in one direction and then the other, you can pre load the wire so that it has enough length when it is at the midway point to turn in either direction. You must limit the rotation so that you do not exceed the length of wire. You can also run the wire down the inside of the tube. The PWM cable can stand a fair amount of rotation over the full length of the tube without failure. Perhaps as much as +/- 5 turns especially if you use an extension PWM cable. Please remember that you can use surgical tubing to hold the wire out of the way if needed, up to the specified size please.
If you require continuous rotation, then I will have to think about it for a while. Nothing in the rules that I can think off would allow you to continuously rotate the tube. If you would care to PM me, I might be answer better off line so that you don't give away your strategy.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-12-2009, 21:19
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
connect a tube clamp to the structural tubing and then connect a motor hub to the tube clamp then the motor shaft can be slipped into the motor hub and it'll spin as you want.
TUBE-TUBE CLAMP-MOTOR HUB - MOTOR
Unread 18-12-2009, 21:29
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Dont forget to put a tube plug in there for more support
Unread 21-12-2009, 10:50
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
That Tube Plug seems pretty useless.
We tried using them, and even when we clamped down hard on the tube with the tube clamp, the plug was still loose and just fell out the end.
Did we do something wrong?
I would have assumed a tighter fit.
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
need help with gyro sensor connection alaa abo alheja Sensors 8 31-08-2009 04:52
pic: John testing Surgical tube connection falconmaster Extra Discussion 20 10-01-2009 11:25
[FTC]: Random Error with FTC motor control Xaphiinia FIRST Tech Challenge 2 01-12-2008 15:39
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
