Go to Post "FIRST is like a pizza, we all think different toppings should be on it" - Andrew Schreiber [more]
Unread 19-12-2009, 01:54
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Historic Size of Battery
To familiarize our students with a revised design process, we decided to design a new battery cart and went through all the steps of the process. The students really like the new design that came out of it comparing to our current battery cart and they want to build it.
I am aware that FIRST has changed the battery teams are allowed to use before. Does anybody know if the size of the batteries in past years are all about the same size? If we know that the size changes, then we will use the maximum dimensions from previous years so it will accomodate most batteries. Does anybody know if we will be using the same battery next year?
Please don't call me Mr. Ed, I am not a talking horse.
Unread 19-12-2009, 02:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Historic Size of Battery
The batteries have all been identical in physical dimensions for almost a decade, if not longer.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-12-2009, 09:24
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
First has changed batteries in the past. Initially, (1996) the batteries used were drill batteries and plugged into the drill housing for each drive motor. As things progressed and First adopted the IFI controllers, we started using the motor cycle battery in the size which we are now using. However, over the years, the battery has changed vendor, terminal arrangement, and chemistry (gel vs. AGM), each of which produces a slightly different size. Current batteries expand with heat, so if you make the tolerances small, it is possible you won't be able to remove the battery as temps flucuate.
As First and their vendors change, so to will batteries. There has been some talk for a year or so, that MK is working on a newer battery. It is more powerful and I expect it to be a little larger then the current battery.
I have seen many battery carts, but designers should remember that hot batteries do not charge properly and although the battery can be used in any configuration, charging is best done with battery terminals up.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 19-12-2009, 19:13
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Team Role: Mechanical
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Originally Posted by Al Skierkiewicz View Post
...that hot batteries do not charge properly and although the battery can be used in any configuration, charging is best done with battery terminals up.
What do you mean when you say charging is best done with battery terminals up? If you charge it on it's side, are there any negative affects?
If anyone else knows about charging orientation?
Your reply is greatly appreciated.
Thanks,
Jason Law
Unread 19-12-2009, 19:27
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Thanks,
Jason Law
Al is much more experienced here, so anything I say takes a very distant second to anything he says.
A typical battery that size has a liquid or gel in it--something that can flow within limits--and a series of plates. Essentially, there is a chemical reaction happening. When the battery is recharged, the reaction is reversed. The reason to recharge upright would be to ensure that the plates are fully coated for maximum reverse reaction occurrence, or more speed/better depth of charge. Discharging can be done in any orientation because the reaction will concentrate in the contacted area. Charging, you don't necessarily want that.
Oh, and charging on the side has another drawback: should a seal break, the acid or other liquid can leak. Charge upright, and it's easier to clean up than if it spills out.
Oh, and for those inserts: there is a type of pink foam that is fairly dense, closed-cell, I think (not sure of exact type/brand). It cuts easily with a hotwire, great for spacing/organizing.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-12-2009, 19:31
Jason Law's Avatar
Team Captain
Thanks for the quick reply. Would you say that charging on the side shortens the life of the battery or would it simply not charge fully?
Thanks,
Jason Law
Unread 19-12-2009, 19:35
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Thanks,
Jason Law
I defer to Al on that one, because I don't know. Here's what I know about batteries:
1) You charge them, they work, unless there's something wrong.
2) Typical lead-acid or gel-type construction internals.
3) Typical FRC batteries have a joint near the top and none visible near the bottom.
My response was based on 2) and 3) in that list.
Past teams:
Unread 19-12-2009, 20:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Al seems to be more concerned about the battery being able to vent properly
http://www.chiefdelphi.com/forums/sh...87&postcount=7
Unread 19-12-2009, 20:31
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Here's MK Battery's reference document for sealed lead-acid batteries: Valve-Regulated Lead-Acid (VRLA) Technical Manual. There's a lot of excellent advice in there regarding best practices.
Unread 19-12-2009, 21:07
Unsung FIRST Hero
Rookie Year: 1996
The document that Tristan has linked to is part of the references I have used in the past. The current battery is an AGM style battery so the electrolyte is absorbed in a mat but can become fluid under certain conditions. I recommend charging upright so that any fluid that might be present doesn't cover the pressure valves. Should pressure build to the point of venting, loss of fluid is inevitable. For the students handling batteries, if we make it a normal procedure to charge upright, then should they be in position where they are charging some other types, the vents will likely be facing up. If the battery experiences some failure during charging, then all venting will take place where pit crews can see it and react ASAP. We are not sure at this point what failures may have occurred, but a small number of teams have experienced battery failures over the last two years. Some have occurred during charging and the rest appear to be physical damage. Since the battery stores a large amount of energy, physical damage can cause internal heat. The domino effect causes venting, external heat, and leaking fluid. Please instruct your students to never handle the battery by the wiring, always carry with two hands and in the event of a drop, be sure to put the battery on the side until you (or another mentor) can determine if it has internal damage. A few hour test with a load tester like the West Mountain Radio CBA II will show if one or more of the cells have a reduced capacity indicating internal damage.
Al
WB9UVJ
www.wildstang.org
Unread 19-12-2009, 23:03
Ed Law's Avatar
Thank you to all who responded so quickly and thoroughly in the answers. We were in the middle of finalizing the design tonight and the students wanted to understand why the batteries can not be charged sitting on its side.
Our original design would have the batteries laying on its side with the top facing out when charging in the pit. At other places where space is not a constraint, we will lay the battery cart down on the back which is on wheels so all batteries will be upright.
Now at the pit, we can either lay it on the back and put it under the table or take the batteries out of the holder that carries two batteries and set it upright without the holder in the battery cart. Either way we are going to charge it upright. It may be hard for others to understand what I am talking about. We did manage to finish the CAD model tonight. We are going to tweak it a little, put in the details where the holes are to run the charger wires, power strips etc. We will post it here for you to see at a later date. It is really cool.
Unread 19-12-2009, 11:04
DonRotolo's Avatar
Back to humble
FRC #0832
Al said it well.
I would just add that having an extra inch or so for fingers to get at the batteries is valuable. If they rattle around, some closed-cell foam can be cut to take up the space yet leave flexibility for the future. (Foam that's soft but quite stiff, made of a slippery plastic I think is polyethelyene. Usually found in white, it is not styrofoam)
Unread 19-12-2009, 11:46
MrForbes's Avatar
AKA: Jim
Another thing you could do is to get all the design work done, then hold off on building the car until after kickoff, when you know for sure what the batteries will be.
Or if you're into assumptions, you could read the list of rookie/veteran parts variables
http://usfirst.org/uploadedFiles/Com...write%20up.pdf
and assume that since veteran teams are not getting as many batteries as rookie teams, that the same batteries will be used next year. But note that it also says that battery rules are under review.
Unread 19-12-2009, 15:35
Ed Law's Avatar
Thanks Cory, Al, Don and Jim,
We will modify our design slightly to charge the batteries in upright position.
We will leave half an inch in each direction to accomodate slightly bigger batteries in the future and swelling during charging.
We will put inserts to take up the slack and change them to different sizes to accomodate batteries of different sizes in the future. I like the idea of using light weight slippery plastics. What will be a good way to secure these inserts that is removable?
We are going to CAD it tonight and build it during Christmas holidays.
  #15   Spotlight this post!
Unread 19-12-2009, 17:35
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
The loopy side of velcro should do the trick, and it's soft enough that if a battery needs to be inserted without any plastic spacers, it would just slide past.
Alternately, depending on how its built, the spacers between batteries themselves can be adjusted. I'm looking for a picture of my team's station to tell you what I mean...
Historic Match Results Greg Marra General Forum 6 02-04-2008 18:38
Pit Size Super Serb Technical Discussion 24 09-03-2008 17:43
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
size great_one411 General Forum 3 06-02-2003 09:02
Project Size stevet75 Inventor 0 13-03-2002 21:21
