Go to Post Funding and success is no accident. - waialua359 [more]
Unread 20-12-2009, 14:07
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
pic: Wheel 4 V1.2
Ok. I do apologize. I had some of the measurements off.
Spoke Depth - .375 inches
Spoke Thickness (Bottom) - .275 inches
Spoke Thickness (Top) - .15 inches
(Neither of those include the fillet.)
Unread 20-12-2009, 14:08
CraigHickman
Posts: n/a
Re: pic: Wheel 4 V1.2
Your spokes seem too thick, IMO. You ought to be able to pull off at least .25" thick.
Looking good, it's nice to see the evolution of this design!
Unread 20-12-2009, 14:27
I love the progression of your design, Rion. Keep it up.
What's the size of the hex?
Unread 20-12-2009, 18:49
The CAD Guy
I edited the post. I had some of the measurements off. I do apologize.
Thanks. More detailed can be found here.
Thanks Akash.
The radius of the hex is .5 inches. Same as Andy Mark. I know. Looks big to me as well.
Unread 20-12-2009, 22:34
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
OK, be careful with this. If the wheels will be used in a swerve/crab application on carpet and your wheels will have a decent CoF, the spokes need to be beefier than you think.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 20-12-2009, 22:57
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Just to reiterate what Raul is saying here...
If you are using solidworks or inventor you have built in tools that allow you to do some quick FEA on your wheel. Instead of guessing at something being too beefy or not beefy enough, why not do some analysis?
For starters when it comes to wheels I do this:
Knowing that a wheel can only exert a certain amount of force on the ground and vice versa we can use the coefficient of friction with the wheel and ground as a starting point. The wheel will be under the most load when it is being pushed sideways along the carpet RIGHT before it loses traction with the ground. So estimate the weight of the robot and determine the normal force on one wheel. Then you will be able to determine the frictional force acting on your wheel. Use this as a baseline (ie safety factor = 1). You can then put this exact force on your wheel in Solidworks Simulation (or some other FEA software). Support the wheel right where the shaft would be and start your analysis. You are definitely going to want to bump the safety factor for a FIRST robot, and especially since this is just a rough calculation. To do that just multiply your frictional force by 3, 4 or 5 or whatever you want. Look at your stresses, compare them to the yield stress of the material you are using. Look at your deflections, make sure they seem reasonable (ie not half an inch or something like that, you want to be in the couple of thousandths range). Look at your stress concentrations and see if there is some simple geometry fixes you may be able to incorporate to alleviate them.
Analysis is a very powerful tool that starts taking things from a guessing game to concrete answers. I highly recommend learning to use it effectively. Keep in mind though that analysis isn't everything, and one small assumption you make can throw off your whole analysis.
Good luck, the wheel looks great so far.
Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 21-12-2009, 07:47
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
I second Brandon's suggestion. Additionally, be careful when looking at the visual representation of the deflected model. The deflections illustrated are typically exaggerated to make them more easily identified, so be sure to look at the numbers provided instead.
Mark
Brick walls are for other people. - Randy Pausch
Unread 21-12-2009, 15:41
CraigHickman
Posts: n/a
I wish I could make this bolder. Trusting your intuition only works as well as the human brain. Numbers and raw data are far more effective.
Cough
. It's possible to pull off some VERY light wheels while still maintaining plenty of strength. Those are 1/4" Thick spokes, two 1/4"x1/4" bar per spoke area. In the bottom wheel, the ends are radiused for extra strength (and style).
Unread 21-12-2009, 15:49
The CAD Guy
Cough
For one. I would like to point out that the average human only uses 10% of the brains capability.
Back on target. I honestly have no idea as to how to use the stress analysis. I know what buttons to press. Just not how they should be pressed. If that makes sense..
Yes it is possible, but I would like to leave VERY light for a later date. For now I would like to stick with getting at least one wheel out that weighs less than .35 pounds. If I can do that I'm happy.
Unread 21-12-2009, 16:20
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Cough
I believe it's side loads that Raul was worried about. Your extra strength radius doesn't seem to address that.
Unread 21-12-2009, 18:40
CraigHickman
Posts: n/a
Erm, yes it does. Please examine the lower wheel closer. The wheels were "dished" out by a .5" radiused end mill, in order to increased the side load ability of each wheel.
Unread 22-12-2009, 10:44
Software Architect
It's possible that I'm not seeing something in the picture that you know is there. The extra widening on the ends of the spokes would seem to be helpful only in the normal direction of travel of the wheel. To be stronger in the sideways direction, the spoke would need to be thicker where it meets the hub.
(It's also possible that I don't know what I'm talking about, as I'm more attuned to software than hardware, but I think a couple of seasons of kit wheels from AndyMark did a good job of showing how side load stresses need to be dealt with.)
Unread 22-12-2009, 13:11
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Craig is talking about the wheels his team built I believe 2 seasons ago that he linked to on this thread. Those wheels have a .5" radius where the spokes meet the rim. This absolutely strengthens the wheel in side impacts and can be verified by a quick FEA analysis. Adding this inner radius is a simple way to increase wheel strength without much extra work.
Mentor 2415
Unread 22-12-2009, 14:35
CraigHickman
Posts: n/a
Completely correct. My machinist was also able to use a single tool for the majority of the job, which greatly sped the process up.
Rion, when can we see the next version? I'm looking forward to seeing your progress!
  #15   Spotlight this post!
Unread 22-12-2009, 14:43
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Cough. Ermm. excuse me, other rude phrases...
Alan was correct, in that the small radius there doesn't really solve the problem Raul stated. If your spoke is too thing to handle the side load, a small radius really isn't going to fix the problem; and if that little bit makes the difference, your factor of safety is too low.
Please, try to learn to have a discussion on here without being rude and insulting people.
pic: Pic 2: "caster wheel" crab drive combo adengler Extra Discussion 7 27-01-2009 21:14
pic: Pic 1: "caster wheel" crab drive combo adengler Extra Discussion 1 25-01-2009 17:44
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
