2010 Control System Getting Started
I spent a good 20 minutes trying to get up to speed with the FIRST forum Beta posts. I was disappointed at the lack of software posted for the # of Beta teams supposedly testing this software.
Here is a quicklist of Beta Documentation ! Introduction Presentations 67 - Java Overview 330 - Labview Feature Overview Java Early Access 1089 - Java Test Documentation 1279 - Java Presentation Labview Code Samples 330 - BeachBots BETA Code 1718 - Labview Code - Java Code Samples 341 - Miss Daisy Code 339 - Kilroy Code C++ Code Samples 67 - HOT Team Code Hardware 67 - CAN Presentation 330 - Drivers Station 2009 Documentation is still useful but outdated What alarmed me the most is that Labview will not be releasing the library upgrades until after Kickoff ? Not being able to download and test the software is a big setback to non-Beta teams for FIRST preparation. |
Re: 2010 Control System Getting Started
I think my team (1714) is planning on posting something before Kickoff, if you're looking for C++. Not sure on the progress, I'll find out next meeting.
I've said it before...
I don't believe that it is right to give a handful of teams an advantage by letting them 'beta' the control system. Maybe it would be better to open source the whole thing and see what the FIRST community comes up with. JMHO. |
Any team could have used the 2009 FRC software to practice programming and gotten as much or more out of it than the 2010 Beta Testers. They could have focused on using the system and getting useful results. Anything added or changed for the upcoming year won't take away the benefit of that practice. The teams involved have spent significant effort using tools that were just short of ready, finding and overcoming obstacles, documenting (and often correcting) errors, redoing work when updates occurred, exploring use cases that weren't considered by the developers, troubleshooting problems with the libraries, helping to make the documentation useful, and generally making it possible for the rest of the teams to get a system that works well out of the box. What these "privileged" teams have done over the past few months is only slightly relevant to what they will have to do after Kickoff. I don't think working with the unfinished software has given them a significant leg up on everyone else, and I know their work is going to give everyone else a better experience than they would have had otherwise. |
According to Bills blog, 43 teams were set up as beta testers (Sept 3), yet the OP states that only 7 teams have provided results. Most of which does not include specifics about the changes in FPGA code or how much editing it will take to convert their labview/C++ code to Java (Things that at least 20 of the beta teams have done). My suggestion in my previous post was not an indictment of the teams, but rather a suggestion that we look at open sourcing the libraries to all of the FIRST teams and see what comes of it. My question back to you is: If there is nothing gained by having the software, then why are you so against opening up the beta process to all teams? |
where did he say he was?
The goal is to shake out problems in a manageable way with a limited number of resources. Some resources have to manage the beta process (deliver updates, answer questions, feed information back to the developers, etc) and other resources are trying to finalize the product (finish promised features, internal QA, roll in beta feedback). If resources are limited, which I assume is the case especially in this economy, then a limited managed beta is more productive than an open sourced test. If new hardware is required, that is another resource that can constrain the size of the beta test. |
Your post had two points. I chose to answer only the first one. The second one seemed too speculative to address well.
I'm not quite sure what you mean by "open source", though. Are you asking for WPI to make the libraries available for anyone to modify? Quote:
If I did want to explain why limiting the process to relatively few participants is appropriate, I would give pretty much the same answer Richard did. |
The things that Phil, Joe, Rick and the rest of the beta-ers do behind the scenes would astonish you. What they publish is only a small part of their contribution. What they are really contributing is scraping their knees against our mistakes over and over again until we figure out how to fix it. Please do not assume that because you have not read a document with someones name on it that they have not directly contributed to your experience. |
#10
First off, I truely believe that the beta testers are teying their best to help the FIRST community, and I don't doubt that they do a lot more than what we see. My hat is off to those who have worked so hard to get the teams a excellent set of hardware and software.
but ... and I guess this was the point of my OP ... It is difficult to deny that having the software/hardware to use/work with/play with doesn't give you a familiarity with it that teams that do not have the new wiz-bang stuff don't have. And, as far as open source, I was talking about the libraries. Seems to me we could create far more, and debug them far faster as a community. I also believe that this would be an excellent learning oppertunity for those who take part. P.S. Alan -- I apologize. You were silent on opening up the beta process. It was not my intention to create a strawman argument. |
#11
#12
I can confirm that the beta test ran pretty much the same as most others I've been a part of. People have good intentions, they are gung-ho and sign up for the beta, but then life happens and there are only so many hours in the day. Some teams are able to be far more active than others. I suspect you will continue to see code posted in the coming weeks. Beta testing is certainly not easy, and not fun. The additional responsibilities placed on the team may indeed cause them to excel, but it is more likely to be organizational rather than competitive success, IMO.
As for the LV upgrade, I'm glad to hear you are looking forward to it, and I'm sorry to disappoint, but you will have to use 2009 tools until kickoff. There have been a number of presentations detailing the new feature to the WPI libs, and I'll be happy to wax poetic about new features, but the SW is part of the kit of parts, and my observation is that if it isn't brand new, then it will likely be treated as any other kit element. At least they still allow us to present and teach about the new features before kick-off. As for open sourcing WPI Lib, the following is placed in each file in the LabVIEW WPI Lib implementation, and presumably in each file of the other language implementations as well. * Copyright (c) 2009 FIRST, NATIONAL INSTRUMENTS, WORCESTER POLYTECHNIC INSTITUTE AND THEIR LICENSORS * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * Neither the names of FIRST, NATIONAL INSTRUMENTS, WORCESTER POLYTECHNIC INSTITUTE, THEIR LICENSORS-nor the * names of their contributors may be used to endorse or promote products * derived from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY FIRST, NATIONAL INSTRUMENTS AND WORCESTER POLYTECHNIC INSTITUTE AND THEIR CONTRIBUTORS ``AS IS'' AND ANY * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL FIRST, NATIONAL INSTRUMENTS, WORCESTER POLYTECHNIC INSTITUTE OR THIER CONTRIBUTORS BE LIABLE FOR ANY * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. I'm no lawyer, but that seems pretty open source, and with a public repository such as FirstForge, all sorts of team-improved features could become part of the libraries or could spawn alternative derivations. On the other hand, this doesn't remove the benefit of targeted beta programs, especially when there is HW being developed in tandem. It always has more limited availability. So, perhaps in the future the SW development will be a combination of all these good ideas. Greg McKaskle |
#13
Excuse my ignorance, but are any major changes being made to the existing C++ base, or does the C++ update mostly contain bug fixes and better implementations? What new functionality is being added, and what changes should teams planning on using C++ be aware of?
#14
There are some C++ presentations on the FIRST site which may have more details, but there will be additions to the library for the I/O board, vision has been redone I believe, and there is a serial port proxy console.
Greg McKaskle |
#15
Greg,
Can the presentation at Kickoff in NH on enhancements in code and hardware to the Control System be webcast, or recorded and posted later that day? |
| Problem Getting Victors to run with the new control system | Boommaster713 | Programming | 11 | 15-02-2010 15:29 |
| Unclaassified: Information about the 2010 control system | Nadav Zingerman | General Forum | 35 | 24-11-2009 19:17 |
| 2010 Control System Beta Testers Posted | Jared Russell | Control System | 3 | 04-09-2009 16:40 |
| Bills Blog: A few more details on control system and 2010 beta test | Joe Ross | FRC Control System | 3 | 13-08-2009 13:52 |
| Getting Started | Cheese Head | Programming | 4 | 09-10-2002 22:24 |
