Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
Unread 23-12-2009, 15:26
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: First Robot
The cart Andy suggested is basically what my team has used the past few years. They are available from a ton of manufacturers, and are customizable to your own needs. Last year, we mounted a plywood deck for the robot to sit on. If you choose to do this, ensure it is strong enough to handle the robot (If it isn't, injuries will occur).
Also, you should consider your robot's center of gravity in whatever you build (we almost dumped our robot off the side of the cart a few times last year).
Flashy carts are usually a waste of money, I would much rather have a flashy robot .
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 24-12-2009, 00:20
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: First Robot
Chris has some great points, but here's some additional information (shown in red) that 228 has learned from about a half dozen different iterations of homemade robot carts over the past twelve seasons. We've learned all nine points the hard way at one point or another.
Originally Posted by Chris is me View Post
As someone who had to push around a robot cart for four events last year, a few things:
1. Big wheels (pneumatic tires or rubber) make going over gaps and wiring sections on the floor much easier. 3 inches of ground clearance in the middle is perfect, less requires some work.
2. A solid removable handle is significantly better than a rope handle.
Nothing is more annoying (or a potential safety hazard) than having a solid, non-removable handle. Having an easy to remove solid handle allows you to remove the handle to work on the robot and make it easier to lift the robot onto/off of the cart. This can be something as simple a bent or welded piece of aluminum tubing than can slide into a slot in the cart.
3. 2 (at the end of the cart opposite of the fixed handle) and 2 omni / swivel casters (at the end with the handle) works well for maneuverability; four casters is a little harder to control with just one person.
When you put the casters at the end opposite the handle, you'll have a large rotational moment when trying to turn the cart. If you put the casters at the same end as the handle, it'll be much easier to rotate the cart.
4. If you are going to build your own cart, while storage for stuff like the driver station is nice (not required), storage space for spare batteries and bottled water should be provided. but your drivers will thank you if they have a spot to throw the controller. (Some robots have room on them for this kind of stuff).
Having storage space for batteries will save you from running to the pits, and having storage space for ample bottled water will literally save you. We once had a member of our drive team collapse during the elimination rounds five or six years ago from dehydration. Since then we've taken aggressive measures to always have ample bottled water (or Nalgenes+drinking fountain) at all times.
5. Some events (cough 10,000 Lakes cough) have only 32 inches of clearance for your cart. Long way forward and no wider than your robot is the best solution, or at least a way you can shrink it.
Standard doorways are between 30-32 inches wide, so this should be a universal standard.
6. Most FRC robots are a maximum of five feet tall. Remember this when building a cart. The maximum height of a robot on top of the cart should be less than the maximum clearance height of the lowest doorway you'll encounter.
7. Your robot will change every year, but when you finally build a cart, build it once. Therefore, design in an easy to change method for holding the robot every year. One good solution is to mount blocks on pieces of 80/20 (or other similar extrusion), to slide to new positions every year.
8. If you have a giant flat surface, put a lip on it. There will be times where you'll have loose hardware from a mechanism on the cart that's still being assembled as you rush back to the field. Having lips on the cart will prevent that loose hardware from getting hopelessly lost.
9. Make your cart lightweight. Don't make it motorized, don't put on surround speakers, don't have permanently attached toolboxes, etc. Make it carry the robot, carry spare batteries, and potentially carry the operator interface. Anything else should stay in the pits.
Here's a photo of the homemade (wood) cart 228 has been using since 2006, which incorporates all of the above features:
with handle removed:
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 23-12-2009, 23:08
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Re: First Robot
Originally Posted by Andy Baker View Post
This is what I suggest using as a robot cart (or something similar):
Andy B.
On sale, with coupon for $89.99 until 1/14/10 at Harbor Freight.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Your first robot Akash Rastogi Robot Showcase 23 20-01-2008 12:24
First time wiring a robot Andy L Electrical 18 07-04-2007 09:13
Part Four: The FIRST Robot Rock Opera: The Robot Rebellion Gabe Salas Jr. General Forum 0 14-03-2007 17:57
**FIRST EMAIL**/The FIRST Robot Chicks Union Amanda Morrison FIRST E-Mail Blast Archive 4 11-06-2005 12:56
