pic: Chassis Idea
Re: pic: Chassis Idea
Looks really good!
Nice Work! A couple suggestions: You could definitely get away with 1/16 inch wall tube on the inner parts of the frame to save some weight. I'm assuming you're welding the extrusion. The other thing is that my team found is if you cut the edges of the square tube extrusion to 45 degree angles where they meet at the corners, it is more structally sound. Are those wheels the ones you posted before? Looks really nice, the rendering makes it look very appealing. Last edited by sgreco : 12-31-2009 at 10:40 AM. |
I see you have really been hitting up the CAD software recently! Awesome work!
---------------------------------------- | High Friction High Friction | | | | High Friction High Friction | | | | Omni Omni | ----------------------------------------- |
Very nice work! This is about as simple a box frame chassis as I've seen, and it is definitely a good start towards a top notch final design.
Some things to think about when designing a chassis (obviously some of these are dependent on the game and rules):
Hope this helps! My only two questions/comments about your particular chassis are (1) if there is a ramp to climb, you will probably want to move your wheels further to the front and rear of the frame and (2) how do you plan on supporting the plywood base in the middle? Last edited by Jared Russell : 12-31-2009 at 01:11 PM. |
We are hoping to be able to weld it. Money and knowledge may hinder that though. If we can not then we will be creating brackets out of 1/16" Aluminum and riveting it together. The wheels are a more recent version of what I posted. A picture of them can be found here. If you go over one you can see it with the gear. (I haven't put the bolts in yet. I am about to do that when I have finished this post.) Thank you for all of your help. Quote:
I currently have a center drop of 1/16. I apologize for not mentioning that in my description. Thank you for the tips on maneuverability. ![]() Quote:
That is a good point, I had not thought about any ramps. The nice thing is that no design changes will need to be made; just the location of the wheels. ![]() I am considering that at the moment. I have thought about mounting an aluminum cross beam in there. Do you have any suggestions? -Rion Last edited by Rion Atkinson : 12-31-2009 at 01:16 PM. |
Looks good.
I'm wondering...did you want the wheels on dead axles or live? |
The wheels are on live axles. Sorry about that. -Rion |
Hopefully someone with more experience with 6wd can post here (I've never built a live axle system before) but what is the purpose of having a live axle system? To my understanding, the occasion when you use a live system is when the gearbox is directly driving either the center wheel (live) or a corner wheel but then the other two wheels are on dead axles.
Someone want to clarify this for me? |
#10
I meant to ask the question in general too. Is there less loss of power when using live axles or something? What is the benefit, if any?
#12
Some setups may only function with a live axle setup. However given the choice between dead or live axle....I use dead axle wherever and whenever I can. Art- If your supporting the shaft on both sides anyways (assuming a wheel your using can have a bolt pattern), then bolting each end of the shaft in place is even more simple IMO, instead of having to turn down the ends of the shafts. -Brando Last edited by Brandon Holley : 12-31-2009 at 01:51 PM. |
#13
Drilling and tapping the ends takes three: a center drill, the drill bit, then the tap. On a manual lathe, it's faster to turn the ends down. |
#14
I will sum up my experiences with live and dead axles below.
Live axles are useful because:
Dead axles are useful because:
Did I miss anything? |
#15
# of tools is kind of an unfair comparison here. Drilling the ends of a piece of stock is probably the simplest operation you can do on a manual lathe. No zeroing (assuming your going to just do a rough estimate of depth because your tapping the hole anyway) and no measuring of the piece to ensure correct diameter. My guess is that the lathe operations would take close to the same amount of time for both kinds of axle, including the tool change for the drill. The tapping will cause the dead axle to take a longer amount of time, but we're talking about a matter of minutes which I do not feel is enough to justify changing a design from dead to live. There are a ton of other considerations obviously, but I just wanted to point that out. -Brando |
| pic: Chassis Idea | Rion Atkinson | Extra Discussion | 17 | 08-25-2009 01:24 PM |
| pic: Chassis Driving 2 | Hanna2325 | Extra Discussion | 4 | 01-12-2009 11:13 AM |
| New AM C-Base Chassis vs. Old IFI KitBot Chassis? | ChuckDickerson | Kit & Additional Hardware | 5 | 01-06-2009 08:36 AM |
| pic: 2430 Chassis | Boydean | Extra Discussion | 2 | 02-09-2008 12:10 PM |
| New Format - Good Idea/Bad Idea? | Harrison | Chairman's Award | 4 | 11-07-2002 04:28 PM |
