Go to Post STEM blushes, and asks if Art would like to go out for a date. - Cothron Theiss [more]
Unread 31-12-2009, 10:34
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
pic: Chassis Idea
Unread 31-12-2009, 10:38
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: pic: Chassis Idea
Looks really good!
Nice Work!
A couple suggestions:
You could definitely get away with 1/16 inch wall tube on the inner parts of the frame to save some weight.
I'm assuming you're welding the extrusion. The other thing is that my team found is if you cut the edges of the square tube extrusion to 45 degree angles where they meet at the corners, it is more structally sound.
Are those wheels the ones you posted before?
Looks really nice, the rendering makes it look very appealing.
Unread 31-12-2009, 11:41
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
I see you have really been hitting up the CAD software recently! Awesome work!
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 31-12-2009, 12:38
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Originally Posted by Formerly Famous View Post
My thoughts would be if you make it so that you can slide the battery in through the larger holes on the front (or back), and (this is something 190 did a while back) since you have a six wheel base I suggest moving the middle wheel down from the outer wheels. This is a common base that will tilt when you move allowing for a smaller turning radius and better maneuverability. This sometimes creates to much maneuverability or to little, depending on your needs. So in order to give yourself more, or less, maneuverability you can put high friction wheels in the middle and back sections and have the last two be omni wheels. This way if your driving one way you have high maneuver ability, while driving the opposite direction will allow you to stay more stable and go forward straighter for longer amounts of time without stray.
| High Friction High Friction |
| Omni Omni |
Unread 31-12-2009, 13:06
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Very nice work! This is about as simple a box frame chassis as I've seen, and it is definitely a good start towards a top notch final design.
Some things to think about when designing a chassis (obviously some of these are dependent on the game and rules):
  • How will we ensure that our chains will be properly tensioned?
  • How we will adjust the drop of the center wheel (if any)?
  • How will we mount our bumpers?
  • How will we fix X when it fails? X = wheels, sprockets, chain, gearbox, motor, speed controller, cable, frame members, welds, etc. (and how long would such a repair take?)
  • What sorts of COTS and custom made spare parts will we want to bring to competition with this drive base?
  • Do we have easy access to all bolt heads, nuts, rivets, etc., for tightening or loosening?
  • If something must go to make weight, where will we start?
  • What is the center of gravity, and how can we move it to where we want it to be?
  • How long will it take to build this once build season starts?
  • How much does it cost? Can we lower the cost somehow?
  • What are the wiring paths?
  • Where can we put the battery?
  • How will we lift this thing?
Hope this helps!
My only two questions/comments about your particular chassis are (1) if there is a ramp to climb, you will probably want to move your wheels further to the front and rear of the frame and (2) how do you plan on supporting the plywood base in the middle?
Unread 31-12-2009, 13:09
The CAD Guy
Originally Posted by sgreco View Post
Looks really good!
Nice Work!
Thank you for the weight saving tip! I have been going through all of my options. I wasn't sure if that would be safe.
We are hoping to be able to weld it. Money and knowledge may hinder that though. If we can not then we will be creating brackets out of 1/16" Aluminum and riveting it together.
The wheels are a more recent version of what I posted. A picture of them can be found here. If you go over one you can see it with the gear. (I haven't put the bolts in yet. I am about to do that when I have finished this post.)
Thank you for all of your help.
| Omni Omni |
I currently have a center drop of 1/16. I apologize for not mentioning that in my description.
Thank you for the tips on maneuverability.
Hope this helps!
Thank you for that list. I have only considered a few of them, and I will definitely be keeping all of that in mind as I perfect this design.
That is a good point, I had not thought about any ramps. The nice thing is that no design changes will need to be made; just the location of the wheels.
I am considering that at the moment. I have thought about mounting an aluminum cross beam in there. Do you have any suggestions?
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 31-12-2009, 13:13
Looks good.
I'm wondering...did you want the wheels on dead axles or live?
Unread 31-12-2009, 13:20
The CAD Guy
Originally Posted by Akash Rastogi View Post
Looks good.
(Starts editing the OP.)
The wheels are on live axles. Sorry about that.
-Rion
Start Something
Unread 31-12-2009, 13:25
Hopefully someone with more experience with 6wd can post here (I've never built a live axle system before) but what is the purpose of having a live axle system? To my understanding, the occasion when you use a live system is when the gearbox is directly driving either the center wheel (live) or a corner wheel but then the other two wheels are on dead axles.
Someone want to clarify this for me?
Unread 31-12-2009, 13:28
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
As far as I can tell, there is no particularly compelling reason for this to use live axles.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 31-12-2009, 13:30
I meant to ask the question in general too. Is there less loss of power when using live axles or something? What is the benefit, if any?
Unread 31-12-2009, 13:45
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
The benefit of live axles comes from being able to use the axle as the transmission of power to the wheel. As opposed to bolting the sprocket directly to the wheel and placing bearings in the wheel, the live axle setup transmits power from the sprocket through the axle to the wheel.
Some setups may only function with a live axle setup. However given the choice between dead or live axle....I use dead axle wherever and whenever I can.
Art- If your supporting the shaft on both sides anyways (assuming a wheel your using can have a bolt pattern), then bolting each end of the shaft in place is even more simple IMO, instead of having to turn down the ends of the shafts.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 31-12-2009, 13:59
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Turning down the ends of shafts on a lathe takes one tool.
Drilling and tapping the ends takes three: a center drill, the drill bit, then the tap.
On a manual lathe, it's faster to turn the ends down.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 31-12-2009, 14:25
I will sum up my experiences with live and dead axles below.
Live axles are useful because:
  • You can drive them from any point on the shaft (e.g. West Coast Drive where there is a bearing block between the driving sprocket and the wheel).
  • The keyed/hex shaft becomes a "universal" interface for attaching wheels, bearings, sprockets, gears, brakes, encoders, etc. As long as your piece has an (ex.) 1/2" keyed bore, it will rotate along with everything else on the shaft. With a dead axle, you must attach pieces to each other directly, and not all wheel and sprocket combinations play nice in this regard.
Dead axles are useful because:
  • You are minimizing the rotational mass of the wheel assembly and therefore maximizing efficiency since the shaft itself doesn't need to spin. Unless you have a truly massive axle or bad bearings/alignment, however, we're probably not talking a huge difference.
  • In the cantilevered case, you are minimizing torsional loads on ball bearings with dead axles (since the bearings are still centered on the axis of rotation no matter what the deflection of the shaft).
  • The closer together two bearings are, the easier it is to have them stay aligned. In a dead axle setup with two bearings in a single wheel, alignment is trivial. Live axle systems that support both ends of the shaft can get out of alignment more easily.
Did I miss anything?
  #15   Spotlight this post!
Unread 31-12-2009, 16:17
# of tools is kind of an unfair comparison here. Drilling the ends of a piece of stock is probably the simplest operation you can do on a manual lathe. No zeroing (assuming your going to just do a rough estimate of depth because your tapping the hole anyway) and no measuring of the piece to ensure correct diameter.
My guess is that the lathe operations would take close to the same amount of time for both kinds of axle, including the tool change for the drill. The tapping will cause the dead axle to take a longer amount of time, but we're talking about a matter of minutes which I do not feel is enough to justify changing a design from dead to live. There are a ton of other considerations obviously, but I just wanted to point that out.
-Brando
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
pic: Chassis Driving 2 Hanna2325 Extra Discussion 4 12-01-2009 11:13
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
