Go to Post Holy cow! Five years in FIRST and it only gets better! Skyway has supplied wheels to FIRST for ten years. Ten years ago Dean called Ken for wheels. Ken said yes. Man, we love helping you guys and gals get good wheels. ;) Bart at Skywaywheels.com - SkywayWheels [more]
Unread 02-01-2010, 01:34
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Gluing Robot Frames
To branch off from Rion's thread here is a thread to discuss gluing frames which was initially brought up by IndySam as an alternative to welding the frame
Quotes from Rion's thread are the following.
Originally Posted by IndySam View Post
<snip> We don't use welding anymore. Instead we glue everything together. Never had a failure.
Originally Posted by IKE View Post
I would love to hear more about this.
We machine connectors (like 8020 quick frame) that slip inside the 1" square tube and then use Loctite Hysol to bond them together.
You can hit it with a sledge hammer and the aluminum will give way before the Hysol does.
Originally Posted by gburlison View Post
Which Hysol formulation do you use? Epoxy, Urethane, or Polyurethane? Any other information about how you bond the aluminum frame together would be appreciated.
Originally Posted by Trent B View Post
IndySam I am with gburlison in that I would love to hear more about this. I never thought of gluing a frame together but that may be a good alternative to welding as we have a sponsor who could get us the 8020 parts easily enough (if we can't make our own) Do you have any examples of possibly a 2x1 tube connector? If you don't I would still love to see what your 1x1's look like.
Thanks,
Trent
Originally Posted by rc_cola1323 View Post
Someone should really just start a new thread about this. I'm interested as well.
-RC
Originally Posted by Akash Rastogi View Post
This isn't that uncommon of a practice guys, and its fairly easy to do even with 1x1 and 1x2 square tubing. We've done it for the past 3 years or so; however, we machine out nylon and UHMW (and even solid aluminum) blocks to insert into the ends of the tubing. Then simply rivet, screw, or bolt the block into place. The ends of the blocks (or wherever you need) are drilled and tapped. The screw or large rivets are easily replaceable with hard epoxy, loctite, or even gorilla glue (in some areas). And there you have a snug fitting frame connector!
I would like to see Pics of this in action too.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
pic: Team 2775 Frames Greg Needel Extra Discussion 14 27-01-2009 21:11
Problem with freezing frames in LabVIEW pdc LabView and Data Acquisition 2 26-01-2006 01:34
CSS frames Ryan M. Website Design/Showcase 12 03-06-2005 18:30
Delete Animation frames ? eNc IT / Communications 1 21-02-2004 15:27
# of frames Adam D 3D Animation and Competition 8 16-03-2002 22:45
