windriver c++?
Hello
we are trying to write a code on windriver /C++ for mecanum wheels but tell now we haven't succeed to use the HolonomicDrive function and open declaration for it from MyRobot.cpp !! any suggestion on how to find the declaration for the HolonomicDrive functionand how to use it? we also tried to upload our prier code which written by EasyCPro 2008 into windriver any suggestion or advices on how we can use our EsayCPro code in Windirver ,[quote] Code:
the code:
void OmniDrive ( void )
int LeftFront;
int RightFront;
int LeftRear;
int RightRear;
int spin_speed = 80;
int gray_area = 15;
int Y_indicator = 0;
int solonoid_move_up = 0;
int solonoid_move_down = 0;
int solonoid_gray_area = 70;
int left_greper_motor = 0;
int right_greper_motor = 0;
InitPressureSwitch ( 7 , 2 ) ;
// this function mixes the inputs to the motors
// and gives the motors PWM commands to drive
LeftRear = RightFront = RightRear = LeftFront =0 ;
//PrintToScreen ( "Xaxis = %d\n" , (int)XAxis ) ;
//PrintToScreen ( "Yaxis = %d\n" , (int)YAxis ) ;
if ( YAxis > gray_area )
Y_indicator = 1;
else
if ( (gray_area * -1) < XAxis && XAxis < gray_area )
XAxis =0;
if ( (gray_area * -1) < YAxis && YAxis < gray_area )
YAxis =0;
if ( XAxis ==0 || (XTrig && YAxis==0) ) // X or Y move (90 degrees)
//PrintToScreen ( "Triger=%d%d\n" , (int)XTrig ) ;
if ( XAxis > gray_area&& XTrig )
degree_90_fix = - DEGREE_90_FIX;
else if ( XAxis < - gray_area&& XTrig )
degree_90_fix = DEGREE_90_FIX;
else
degree_90_fix = 0;
LeftRear =YAxis -XAxis ;
LeftFront =YAxis + XAxis + degree_90_fix ;
RightRear =YAxis + XAxis ;
RightFront =YAxis -XAxis + degree_90_fix ;
else if ( RTrig && YAxis==0 )
LeftFront = LeftRear = XAxis ;
RightFront = RightRear = -XAxis ;
else if ( XAxis > gray_area ) // Right Turn
LeftFront = LeftRear = Y_indicator * XAxis + YAxis ;
RightFront = RightRear = ((127 - XAxis ) /(float) 127.0) *
YAxis ;
//LeftRear = LeftFront = YAxis + ( YAxis *.75 * Y_indicator )
//RightRear = RightFront = YAxis - ( YAxis *0.25 * Y_indicator
PrintToScreen("Right Turn: XaXIS =%d , Yaxis=%d, leftrear=%
d,leftfront=%d,rightrear=%d,rightfront=%d\n-----------Percent= %f----
\n",XAxis ,YAxis , LeftRear , LeftFront , RightRear , RightFront , (float)
RightFront/(float)LeftFront );
else if ( XAxis < (-1 * gray_area) ) // Left Turn
RightFront = RightRear = -XAxis* Y_indicator + YAxis ;
LeftRear = LeftFront = ((127 + XAxis ) /(float) 127.0) * YAxis
//LeftRear = LeftFront = YAxis - ( YAxis *0.25 * Y_indicator )
//RightRear = RightFront = YAxis + ( YAxis *0.75 * Y_indicator
//PrintToScreen("Left Turn: Xaxis = %d, Yaxis=%d,leftrear=%
d,leftfront=%d,rightrear=%d,rightfront=%d\n----------------turn percent =
%f-----------\n",XAxis ,YAxis , LeftRear , LeftFront , RightRear ,
RightFront ,(float) LeftRear/(float)RightRear);
// The following nominalizes the values for the speed
if ( LeftFront < MAX_SPEED_B )
LeftFront = MAX_SPEED_B ;
if ( LeftFront > MAX_SPEED_F )
LeftFront = MAX_SPEED_F ;
if ( RightFront < MAX_SPEED_B )
RightFront = MAX_SPEED_B ;
if ( RightFront > MAX_SPEED_F )
RightFront = MAX_SPEED_F ;
if ( RightRear < MAX_SPEED_B )
RightRear = MAX_SPEED_B ;
if ( RightRear > MAX_SPEED_F )
RightRear = MAX_SPEED_F ;
if ( LeftRear < MAX_SPEED_B )
LeftRear = MAX_SPEED_B ;
if ( LeftRear > MAX_SPEED_F )
LeftRear = MAX_SPEED_F ;
// Now we add 6 back to the speed
// The speed values are stored in an array from 0 - 13
// with 7 as neutral
// We used 0 as neutral before to allow for seemless addition and
subtraction
// Set the motors and add back 127 for 0-255
// If you need to invert a motor replace with"255-(LeftFront+127)"
SetPWM ( Left_Rear_PWM , (LeftRear+127) ) ; // Output to Motor
SetPWM ( Left_Front_PWM , LeftFront+127 ) ; // Output to Motor
SetPWM ( Right_Rear_PWM , (255-RightRear+127) ) ; // Output to Motor
SetPWM ( Rigth_Front_PWM , (255-RightFront+127) ) ; // Output to
Motor
if ( solonoid_Yaxis > solonoid_gray_area )
solonoid_move_up = 1 ;
solonoid_move_down = -1 ;
else if ( solonoid_Yaxis < (-1) * solonoid_gray_area )
solonoid_move_up= -1 ;
solonoid_move_down = 1 ;
else
solonoid_move_up = 0 ;
solonoid_move_down = 0 ;
SetRelay ( 1 , solonoid_move_up , solonoid_move_down ) ;
if ( Solonoid_push )
SetRelay ( 3 , 1 , 0 ) ;
Wait ( 400 ) ;
SetRelay ( 3 , 0 , 1 ) ;
Wait ( 400 ) ;
SetRelay ( 3 , 0 , 0 ) ;
if ( greper_inital_open_trig && inital_done )
inital_done = 0 ;
left_greper_motor = 1 ;
right_greper_motor = 1 ;
else if ( greper_open_trig )
printf("----------in OPEN trig-----------\n");
left_greper_motor = 70 ;
right_greper_motor = 70 ;
else if ( grepre_close_trig )
printf("----------in CLOSE trig-----------\n");
left_greper_motor = 200 ;
right_greper_motor = 200 ;
else
printf("----------in ELSE trig-----------\n");
left_greper_motor = 127 ;
right_greper_motor = 127 ;
SetPWM ( LEFT_GREPER_PWM , left_greper_motor ) ; // Output to Motor
SetPWM ( RIGHT_GREPER_PWM , right_greper_motor ) ; // Output to
Motor
Re: windriver c++?
Your EasyC code is not compatible with the new system, and will have to be rewritten.
I have not had good luck provided holonomic drive function, luckly that is not a difficult function to write. Following is the code for a Mecanum/Holonomic drive. You need to insert the code piecse into the places noted in a blank copy of the Iterative robot demo project. Code:
//INSERT IN: Variable definitions jaguar NEMotor; jaguar SEMotor; jaguar NWMotor; jaguar SWMotor; //INSERT IN: Constructor //You can change the port numbers if needed to match your robot. NWMotor = new Jaguar(1); NEMotor = new Jaguar(2); SWMotor = new Jaguar(3); SEMotor = new Jaguar(4); //INSERT IN: TeleopPeriodic or main loop float X = m_leftStick->GetZ(); float Y = m_leftStick->GetY(); float Z = m_leftStick->GetX(); Y *= -1; X *= -1; float NW = Y + X + Z; float NE = Y - X - Z; float SW = Y - X + Z; float SE = Y + X - Z; NE *= -1; NWMotor->Set(NW); NEMotor->Set(NE); SWMotor->Set(SW); SEMotor->Set(SE); |
Re: windriver c++?
hello Eric
Thank you for your help we were able to insert the code you sent us into RobotDemo however we are not sure if the mecanum wheels are fully doing all the right moves (it works fine in all direction except to the sides) we think that it could be a problem with not having a gray area specified ?!!! Let us know what you think!! the code, Code:
#include "WPILib.h"
* This is a demo program showing the use of the RobotBase class.
* The SimpleRobot class is the base of a robot application that will automatically call your
* Autonomous and OperatorControl methods at the right time as controlled by the switches on
* the driver station or the field controls.
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick stick; // only joystick
public:
typedef enum
kFrontLeftMotor = 0,
kFrontRightMotor = 1,
kRearLeftMotor = 2,
kRearRightMotor = 3
} MotorType;
public:
RobotDemo(void):
myRobot(1, 2, 3, 4), // these must be initialized in the same order
stick(1) // as they are declared above.
GetWatchdog().SetExpiration(0.1);
* Drive left & right motors for 2 seconds then stop
void Autonomous(void)
GetWatchdog().SetEnabled(false);
myRobot.Drive(0.5, 0.0); // drive forwards half speed
Wait(2.0); // for 2 seconds
myRobot.Drive(0.0, 0.0); // stop robot
* Runs the motors with arcade steering.
void OperatorControl(void)
GetWatchdog().SetEnabled(true);
while (IsOperatorControl())
GetWatchdog().Feed();
myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
Wait(0.005); // wait for a motor update time
Y *= -1;
X *= -1;
float FrontLeft = Y + X + Z;
float FrontRight = Y - X - Z;
float RearLeft = Y - X + Z;
float RearRight = Y + X - Z;
FrontRight *= -1;
KFrontLeftMotor->Set(FrontLeft);
KFrontRightMotor->Set(FrontRight);
KRearLeftMotor->Set(RearLeft);
KRearRigtMotor->Set(RearRigt);
START_ROBOT_CLASS(RobotDemo);
ps open the attachment Thank you again from 1946 programming team |
Re: windriver c++?
If you're not sure replace the joystick mapping code with the following, then support the robot with its wheels in the air, and report how each wheel is moving. Then move the constant to each of the other values in turn, and post the result. This will confirm motor mappings, and wiring to the motors. Code:
float X = 0.2; float Y = 0.0; float Z= 0.0; I assure you no additional code is necessary for a basic mecanum drive. I've used that piece of code many times. Last edited by EHaskins : 06-01-2010 at 08:54. |
Re: windriver c++?
The RobotDrive class has a HolonomicDrive method that does the calculations for you based on a 4 motor drive base. You supply a magnitude and direction of travel (that's speed, direction), and a rotation value. To use it, you have to create a RobotDrive object with the 4 motors.
Check out the documenation to determine what order to list the motors. |
| WindRiver purchase | karatekid | C/C++ | 7 | 21-01-2010 17:04 |
| Windriver | Scarra3 | C/C++ | 1 | 31-12-2009 03:10 |
| WindRiver Errors | ExarKun666 | C/C++ | 7 | 04-03-2009 20:32 |
| compiling in windriver | koreabell | Programming | 4 | 05-01-2009 15:32 |
