Go to Post Deodorant cannot be stressed enough. To quote a teammate "body odor is a body don't-or." - C. De Vries [more]
Unread 06-01-2010, 13:20
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
pic: Chicapus08
Unread 06-01-2010, 13:21
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: pic: Chicapus08
You might want to double up those Omni-wheels. It will move more efficiently since it will have a rolling surface on the ground at all times.
Unread 06-01-2010, 15:18
jamie_1930's Avatar
Team Role: Student
Re: pic: Chicapus08
I actually didn't think of that, thanks for the tip. Next year, if we still go with holonomic, we'll do that, but this year we only had 2 omni wheels.
Unread 06-01-2010, 15:57
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: pic: Chicapus08
I would like to point out that what you have here is not a holonomic drive, In this instance from your posts you are using the omni wheels as just a caster, which would just make this a tank drive.
Holonomic drive within robotics is the ability to move in all direction and rotate independently. This would require either 3 omni wheels located 120 degrees apart, omni wheels located 90 degrees apart, or a set of mecanum wheels.
I am not trying to be critical, I am just trying to encourage you to use proper terminology so that your thoughts and ideas are perceived the way you intend them to be.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 06-01-2010, 16:08
jamie_1930's Avatar
Team Role: Student
Re: pic: Chicapus08
It's fine I'm glad you corrected me on that. As a freshmen I was talking with one of the senior students on the team and we were discussing drive trains, this system was introduced to me as holonomic.
Well I guess next year we'll have to make the real version then
