Go to Post Real engineers don't need sleep... Just ask our bosses! - Mike Betts [more]
Unread 06-01-2010, 16:57
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Powder Coating
Our team is looking into powder coating this year but had a few questions/concerns on how exactly the process worked. First, we were unsure whether to powder coat all the pieces individually or to powder coat the frame as a whole, assembled. I was thinking that if we did the frame as a whole everything would line up and the added dimensions would not be a problem but then (maybe?) the allen keys would not fit in the bolts. On the other hand, if we did it in pieces, I am worried that holes would not line up due to the little thickness. What have other teams done in the past and what is the best solution? Thanks a ton!!! Also any other advice about powder coating would be appreciated
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 06-01-2010, 17:07
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: Powder Coating
The end result of Powder coating is very much like paint, and while it adds thickness, it can always be chipped off. I would recommend breaking your robot down into the farthest assembly you feel you might disassemble to. (ie. just your robot frame). As for holes, you can always ream out a hole with a drill bit after it has been coated, and if thickness is a problem a bit of sanding will fix the problem. I would not powder coat over hex screws unless you think you will never take them out. Remember you can always mask off areas you don't want finished.
The thickness of powder coating depends on a bunch of variables such as partial size, color, etc. typically the range in thickness is between .003 and .005"
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 06-01-2010, 17:16
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Powder Coating
Unless you plan on welding your frame, powder coat the individual parts separately. Team 228 has had a sponsor powder coat a bunch of components for us over the past few seasons. We've designed our sheet metal frame to assemble using either PEM nuts and button/socket head screws or pop rivets. As long as you design around the proper tolerances, the only thing we've ever had to do is bore out the powder coat thickness on any bearing holes.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 06-01-2010, 17:33
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Powder Coating
We've always done our frame in-tact, but it's also always welded by the sponsor that does the powder-coating.
A word of caution about color choice: if the sponsor purchases a special-order powder and you don't use all of the powder this year, next year the color will be "off". As an example, our purple is a specific rich, dark, royal purple at its best. Yet every other year it gets this red-wine tint to it. Usually no one can tell until we put it next to the previous year's robot.
GitHub
Unread 06-01-2010, 17:35
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
Re: Powder Coating
Seeing as how I worked at a powdercoating shop last year, I think I may be able to answer a few questions. Each company is unique and some smaller companies may have size restrictions on how big the parts can be, as the material needs to be cured in an oven. In addition, the metal is sandblasted (very fine) so the powder will adhere. Like Greg said, any sections you do not want powdercoated will need to be taped off (Duct tape for the sandblasting, and painters tape for the coating).
Now for the screw question:
You won't be able to fit a standard Allan key into the screw head, you will have to tape off all screw heads. As well if you decide that you want to powdercoat the robot assembled, held together with Allan keys, you will find the powdercoat will chip around the screw hole if you decide to take the screw out. To prevent this you will need to score around the screw head with a sharp knife (safety is important).
Hope this helps.
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
Unread 06-01-2010, 18:19
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Powder Coating
1726 discovered that painting wood with spray paint, letting it dry, sanding, and painting again leaves a finish that looks almost like powder coating, from a distance.
I envy those teams who have their design/build process working so efficiently that they have time to powdercoat their robot!
Unread 06-01-2010, 18:33
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Re: Powder Coating
Thanks! Hopefully we will be able to fit it into our schedule to get it done, right now we r thinking black
Unread 06-01-2010, 18:41
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: Powder Coating
1323 has powdercoated for the past 2 years. Its a really nice deal.
http://www.chiefdelphi.com/forums/sh...t=powdercoated
We prefer to attach our drivetrain and our mast together.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 06-01-2010, 19:09
JesseK's Avatar
FRC #1885 (ILITE)
Re: Powder Coating
You had time for 2 coats of paint?
GitHub
Unread 30-01-2010, 21:11
Foster Foster is online now
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Powder Coating
We have a full, welded frame that will be ready for powder coat Sunday night.
The place we are sending it wants it Monday / Tuesday so we will loose two work nights (6 hours). We are trying to decide if it's worth it vs the time we will miss. (We do have other things that we can do, so it's not like we will be standing around, but there will be a productivity hit)
Teams that powder coat, some questions for you:
  • How long does it take to get your parts back?
  • When in the season (what week) do your parts go out?
  • Do you do one batch of parts or many?
  • Do any of you coat an assembled welded frame?
Thanks very much!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 30-01-2010, 21:21
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
Rookie Year: 2007
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Powder Coating
Thanks very much!
We have been powder coating for the past few years: it takes around 2-5 days, around week 5 or 6, we do it all in one bundle, and we send our frame welded together and plus all our other smaller parts that we bolt on
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 30-01-2010, 21:32
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Re: Powder Coating
Jim,
interesting that you would point that out.
We spend more time stressed over not having enough time to build the robot, then we do the actual powder coating.
We call our build season the 5 week build period because of it and our open house event.
It really does make a difference for the appearance of any bot.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 30-01-2010, 22:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Powder Coating
Thanks very much!
In the past we have been able to get them back in two days, but this year will likely be 4 days due to the shop being busier. We plan to take ours in this coming Monday, or Tuesday at the latest. We usually try to do everything in one batch, although we might need to go for a second round this year. We coat welded frames, but nothing bolted together during coating.
Unread 31-01-2010, 01:01
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
Re: Powder Coating
wow! done with your robot already or soon.......cant wait to see what you folks have cooked up AGAIN.
Tell me more about the regolith coating. Michael Hill Technical Discussion 24 09-01-2009 09:36
pic: 254/968 Powder Coated Parts ejSabathia Robot Showcase 26 16-02-2007 13:50
Powder Coat System from Sears?!?! Not2B Technical Discussion 33 11-07-2006 05:47
powder coating Ben.V.293 Technical Discussion 0 07-04-2004 22:46
pic: Powder make a difference CD47-Bot Robot Showcase 16 29-02-2004 04:13
