Go to Post Watch out, guys, Lisa's coming.... worse than any hurricane or tornado you can imagine! - KathieK [more]
Unread 08-01-2010, 17:12
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
West coast drive (6wheel) question
Do most of you that use a 6 wheel chassis drive the center wheel directly off the gear box? If so, do you use the optional long shaft from AM? How do you attach the wheel and the 2 other drive sprockets? Can anyone detail this for me?
Thanks
Bruce
Unread 08-01-2010, 17:15
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: West coast drive (6wheel) question
Most West Coast Drives use custom gearboxes. If you are looking to use a toughbox, then you would probably need the extended shaft to directly drive the center wheel.
Here's a good example of how a typical West Coast Driver is set up...
Team 1538 / The Holy Cows, 2005-2016
Unread 08-01-2010, 17:45
RyanS's Avatar
RyanS RyanS is offline
Team Captain
AKA: Power Driver
FRC #0294 (Beach Cities Robotics)
Team Role: Leadership
RyanS has a spectacular aura aboutRyanS has a spectacular aura about
If you're planning to use the Super Shifter, AndyMark now sells a hex long wheel shaft.http://andymark.biz/am-0519.html It sticks out 3 inches longer than the standard shaft so you can attach hex broached sprockets (to drive chain to the outer wheels)and a hex broached wheel directly to the out put shaft. I've attached a picture of a west coast siderail. The material towards the outside of the wheels is bumper support. Hope this helps.
2010 Los Angeles Finalists
2010 San Diego Regional Winners
2009 Los Angeles Regional Finalists
2008 San Diego Regional Winners
2008 FTC World Champions
Unread 08-01-2010, 18:16
Bruceb's Avatar
where do you get the hex broached sprockets and wheel? we are going to use the tough boxes unless we fall into some money. how do you make it work with them?
thanks
Bruce
Unread 08-01-2010, 19:27
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Poke around the Andymark website. They have a comprehensive set of wheels, shafts, hubs and sprockets that work together.
You can visit our site as well. www.team221.com
We have an example of how to build a "West Coast" chassis using Andymark components as well as full cad files for this type of system.
Good luck.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 08-01-2010, 19:29
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Check with AndyMark for wheels/sprockets...
http://andymark.biz/pewh.html
Unread 08-01-2010, 21:25
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Team Role: Mechanical
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
we make These... they are combo super shifter shaft, wheel, and we made our own dog for shifting.... They work really well, if you have 4th axis mill, or an indexer...
I have made these a few times, it can be a pain but its worth it!!!
OUTWORK US
Unread 09-01-2010, 08:10
Bruceb's Avatar
Very nice work but we only have a 2 axis(CNC controled) mill. The third axix is manual.
Bruce
Unread 09-01-2010, 08:25
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Extended Key Shaft: http://andymark.biz/am-0211.html
Matching Hub: http://andymark.biz/am-0077.html
Extended Hex Shaft: http://andymark.biz/am-0396.html
Matching Hub: http://andymark.biz/am-0096.html
Use the hubs if you rather not manufacture your own wheel. AndyMark wheels all come with a bearing bore for a dead axle setup*. Attaching the hubs to these wheels will allow you to run a live axle setup**.
Check out their sprockets page as well. Assuming you're using #35 chain, your choices from AndyMark would be:
http://www.andymark.biz/am-0166.html
http://www.andymark.biz/am-0167.html
McMaster has a larger selection of keyed sprockets if the AM ones won't fit in your design.
* - Dead Axle Setup: Wheels spin on a non-spinning axle
** - Live Axle Setup: Wheels spin together with the axle
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 09-01-2010, 09:34
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
The west coast drive that has been described by everyone else is not the most common drive solution, at least where I am from. However it is a good option to consider if you have the machining capability.
Honestly though, a decent quality 6WD robot can be fabricated from AndyMark C-Base, and the toughboxes by direct chain run. My team last year built the Kitbot, despite not having to. I would recommend it if you want to save some time/money to focus on other aspects of your robot.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
New Bumper Rule makes West Coast drive Illegal? Alan Ing Technical Discussion 24 30-01-2009 10:16
"West Coast" drive? pogenwurst Technical Discussion 32 17-12-2008 19:50
pic: West Coast Drive: Spokane Style CraigHickman Extra Discussion 31 14-12-2008 20:02
pic: West Coast Altered Alex.Norton Extra Discussion 25 13-06-2008 00:13
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
