84 inch diameter vertical right cylindrical volume ?
Does this not make sense to anyone else?
The Finale configuration confuses me. Does this just mean we have to fit in a 90 inch tall by 84 inch diameter cylinder? Or a sphere? If we are tipped does the cylinder rotate? I've read the manual. |
Re: 84 inch diameter vertical right cylindrical volume ?
When the last 20 seconds of the game are in effect, you cant be outside that size cylinder.
If you get tipped you wont recieve penaltys for being too big. |
Take a soda can. Barring stuff around the base and top, it is a vertical right cylindrical volume. (You could also wrap paper around that can for a better impression.) Now expand it to 90" high and an 84" diameter. Fit in it.
As for the question on tipping, I can't find anything saying tipped robots are penalized for going out of their volume. I also can't find anything the other way. Q&A it and see. |
it is slightly confusing, but the cylinder is defined using the robot's coordinate system (flips over with the robot), even thought the cylinder itself is called a 'vertical' right cylindrical volume.
(specifically <R10> During the MATCH, the ROBOT will assume one of two operating configurations. When in each configuration, the ROBOT shall fit within the limits shown below (note: these limits are defined in reference to the ROBOT, not the FIELD). (emphasis mine)) |
So, does this mean that the final configuration must fit inside a 84" diameter cylinder oriented to the robot's orientation, no more than 90" tall? Or is the 90" height separate from the cylinder which would then vary in height depending on the angle of the cylinder?
Seems like awful wording to me. |
The height is of the cylinder. The height of the box is not separate from the box base (normal configuration). The way it works is with orientation to the robot. Therefore, should the robot tip completely onto one side, it is now in a horizontal right cylinder with a 90" length and an 84" diameter.
Sorry, but you lost me... initially Chris is me and Matt C said that so long as your robot fits within those dimensions you are alright, but it sounds like now Matt C is saying that this cylinder is in fact centered on the robot base.
Would the word "right" in the phrase: 84" diameter vertical right cylinder volume, be referring to the fact that it remains perpendicular to the robot base, rather than centered around it? Also if it is so rigidly fixed to the robot, that would disallow extending below the robot base, or would the extension just have to fit inside the 90" height maximum? Which is correct? |
#11
A right cylinder is one where the walls meet the top and bottom at right angles. Think roll of paper towels sitting upright on the kitchen counter.
If the walls of the cylinder are not at 90* to the base of the cylinder, it is not a right cylinder. And the top and bottom would be elipses rather than circles. The cylinder remains aligned in relation to the robot. If the robot tips over, the invisible cylinder tips over too, so it is laying on its side. This is different than what happened in previous games. For instance in Rack-n-Roll, if you tipped over while you were extending to put a ringer on the top spider leg, you probably violated the size constraints. The robot does not have to be centered in the cylinder, it just has to fit into it at all times. |
#12
Thank alot Gary. But also do you think that the bumpers would have to be included within this 84" maximum? or is it just to the edge of the robot perimeter?
#13
I had just missed the note that stated it is in reference to the robot, not the field, meaning that if the robot tips, so does the cylinder. Now I just feel my figure is correct whether the robot shown is upside down, right side up, sideways, or slantways in regard to the field.
#14
alright, thanks for all your help!
#15
the cylinder is always 84" diameter, always 90" tall, the end surfaces are always a circle (no angles involved) and all dimensions are aligned with the robot.
If your robot leans at a 10 degree angle while hanging from the tower, so does your reference cylinder. Again with the soda can - take said soda can and bolt it to your robot such that it is sitting normally (like on a table) when your robot is on the ground. The reference cylinder is always aligned with the soda can. your robot does not need to be centered in the cylinder, just inside it. |
| Non-Cylindrical Bumpers? | Tomasz Bania | Technical Discussion | 1 | 04-02-2008 15:53 |
| Volume Accumulators | rsegrest | Rules/Strategy | 4 | 24-01-2008 14:49 |
| 80 inch diameter? | Pneumaticsman | Technical Discussion | 4 | 15-01-2008 08:54 |
| Going over 6 inch step with 12 inch wheels | Joe P | Technical Discussion | 25 | 12-04-2004 11:15 |
| Volume of tank + tube | blindguyinanorg | Pneumatics | 8 | 18-02-2004 00:32 |
