Go to Post Whatever you do, make it idiot-proof. Not because your drivers are idiots, but because the fewer precision maneuvers they have to do, the more awesome driving (and scoring!) they have time to do. - Ian Curtis [more]
Unread 01-09-2010, 03:15 PM
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
Rookie Year: 2007
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Cool Dimension of Bump
What is the base dimension of the bump in terms of length [trapezoid]
1/2(12+b2)h= area
What is b2?
Unread 01-09-2010, 03:19 PM
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Dimension of Bump
Oh people, please read the manual, but the bump is 12" wide at the top, and approx. 32.5" wide at the bottom, creating a approx. 45 degree angle.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 01-09-2010, 03:20 PM
kirtar kirtar is offline
Alumnus
FRC #0461 (Westside Boiler Invasion)
Rookie Year: 2007
kirtar will become famous soon enough
I don't remember that actually being in the manual. Get game-specific drawing GE-10047 if you want the drawing (it is indeed 33.5 inches).
Unread 01-09-2010, 03:21 PM
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
You might check out http://usfirst.org/roboticsprograms/....aspx?id=16097
Not only will it have the dimension you seek, it has all the field dimensions that you need to build a version for your team. Once you look at the drawings, of course.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 01-09-2010, 03:23 PM
5n1p3r's Avatar
IM 5n1p3r
AKA: Matthew
Rookie Year: 2007
I just figured out the angle of is 45 degrees, therefor the base length is 36"
Unread 01-09-2010, 03:27 PM
AKA: Scott
Correct, I was quoting the size of the support rib, which is shown in the drawing.
Unread 01-09-2010, 03:38 PM
Alumnus
Rookie Year: 2007
That doesn't seem to be right. Did you take into account the portion that is "vertical"? The drawing shows that the its profile is that of a hexagon. The trapezoid is raised up 2.1875 inches above the ground. The height of the actual trapezoid seems to be 10.25" (excluding the portion below it), with a specified angle in the drawing of 10.25, giving a total height of 12.4735 inches.
Unread 01-15-2010, 12:51 AM
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
When I look at drawing GE-10047.pdf, the height of the rib is 12 7/16". When you add the 3/4" plywood on top that makes the height of the bump 13 3/16" without the carpet. Does this seem right? I thought the bump should have been much closer to 12".
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Trailer dimension contradictions? Stephanie.S Technical Discussion 0 01-14-2009 03:21 PM
1/2" bump in field? Doug G Technical Discussion 8 01-30-2008 12:41 PM
<G18> - Maximum dimension StevenB Rules/Strategy 2 01-09-2008 08:48 PM
Line or Bump? Swathi General Forum 2 01-05-2008 04:08 PM
