Go to Post What really matters is what you got out of the FIRST season, and how you can use it to build on what you know. - Adam Richards [more]
Unread 09-01-2010, 16:40
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
Rookie Year: 2007
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
<G29> Robots in opposing zones.
<G29> Defending ROBOT Restriction - Only one opposing ALLIANCE ROBOT is allowed in the opponent’s ZONE. A ROBOT is considered in this ZONE if any part of the ROBOT is in contact with the ZONE's green carpet. Violation: PENALTY; plus a RED CARD if effort to remedy is not immediate.
Obviously two or more robots of the same alliance can be in their zone at the same time.
This makes it very hard to keep the opposing alliance from scoring with your single robot when two of the opposing team come in the same zone.
What are your thoughts? what kind of strategy could combat this?
On the flip-side,
If an alliance brings two robots in their zone it would leave the other team the opportunity to make the situation the same on the opposing teams side, therefore balancing it out...
Also whichever team does that first, assuming they move the second robot from the middle zone to their scoring zone, leaves the opposing team in control of the ball returns...
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 09-01-2010, 16:56
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: <G29> Robots in opposing zones.
My thought on this is, the backbot rule returns! Only, it's now more tricky to play with.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 09-01-2010, 17:10
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Also keep in mind that the balls are returned into the middle section of the field, so it will be necessary for an alliance to have a robot in the middle to move balls towards their own zone.
Unread 09-01-2010, 17:18
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
"backbot rule"?
Adam Spears
Unread 09-01-2010, 17:21
I believe he is referring to Aim High, the 2006 competition, when during parts of the game only 2 bots from an alliance could be on a given half of the field, and one had to remain on the other half.
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Originally Posted by gorrilla View Post
"backbot rule"?
2006. One robot had to stay on a certain side of the field during a certain period of the game. This created a 3 offense vs. 2 defense on the other side of the field during that time; the robot that stayed back was known as the Backbot. Now they're saying that it's got to be only 1 defender against up to 3 offense in 2 openings. The backbot rule returns with a vengeance.
Past teams:
Unread 09-01-2010, 17:29
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
hmm.
It would be counterintuitive to double up in your zone, thereby giving control of all the returns to the opposing team?(assuming the 2nd robot is from the middle zone) How much do you predict this will happen?
Im thinking very much or very little...
Adam Spears
Unread 09-01-2010, 17:32
DiehardCybercard's Avatar
DiehardCybercard DiehardCybercard is offline
zaba do de da, FIRST
no team (AndyMark)
DiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud of
I have thought about this g29 rule as well. From what I can tell Breakaway is going to be a game heavily dependent on strategy. In my mind im unsure how you wold combat the situation you gave. However im excited to see all of the different possibilities this year.
Brett Heininger
AndyMark, Inc. Web & Media
Unread 09-01-2010, 17:42
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
This is a very important rule because with out this an alliance could block both opponents goals permanently and just have one robot scoring for their alliance.
It also leaves open the idea for a defensive specialist bot to play the back zone and be quick enough to defend both goals by themselves.
Unread 09-01-2010, 17:44
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
If you're a single robot defending against two, then have your alliance partners cut the ball flow of your opponents; it will then be up to two against one (in your favor) in the middle field, fighting for the returned balls. Who cares how many robots are there if they have no balls to shoot?
FRC - Team 1885 - Programmer.
Unread 09-01-2010, 20:29
Ryan Simpson's Avatar
Ryan Simpson Ryan Simpson is offline
FRC #1676 (Pascack Pi-oneers)
Team Role: Mechanical
Ryan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant future
That's exactly what I've been telling my team. Having two robots in the middle is the best option. If you get a bunch of balls into your zone, then the other alliance's one defensive robot can only remove them so fast. Then, once you get the majority of the balls into your zone, you could send one of the two middle bot on offense for a 2-on-1 and some easy goals. By controlling the middle of the field, you can control all of the balls and therefore the game.
Unread 09-01-2010, 20:34
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
you also have to remember that the balls will roll into the opposing zones of whoever scored that ball. They will have to go that extra mile. But because of <G29>,the defending robot will have to get the balls to the other side, and stop defending the opposite alliance from scoring.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 09-01-2010, 21:10
Mtg Ruler Mtg Ruler is offline
FRC #1986 (Team Titanium)
Mtg Ruler is an unknown quantity at this point
2 robots in the middle certainly doesnt mean you have control of the middle. even one robot of theirs can do alot to ensure it takes awhile to send them over. which then gives them time to have a defender get the balls in your zone back over to theres.
of course always have 2 in the middle if there arent many balls in the opposing scoring area, no point in wasting a bot like that
Unread 09-01-2010, 21:24
goldenglove002 goldenglove002 is offline
AKA: Alex Epstein
FRC #1311 (Kell Robotics)
goldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the rough
it definitely creates a good strategy arguement. Someone who can mauever well in the opposing zone and block could really prove a to be a competitive robot, no matter what the other alliance members are doing.
On robot in the back playing strong defense with two high scorers up front would be very hard to beat.
  #15   Spotlight this post!
Unread 09-01-2010, 21:35
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Well at least unlike 2006 we won't have all those periods of when you are allowed and not allowed to score to worry about.
Is pinning opposing robots trailers allowed? spiffyspleen Rules/Strategy 22 05-01-2009 16:47
<G29> computerboi1503 Rules/Strategy 7 05-01-2009 01:39
rule <g29> and flag gondorf Rules/Strategy 4 28-01-2007 22:43
Rule G29 stillwaters130 Rules/Strategy 3 08-01-2007 18:14
Lifting opposing robots D. Gregory Rules/Strategy 2 07-01-2003 14:06
