Re: What do you think will be important this year?
What will be important is that a team is able to do one thing "well".
Zone-Zone mobility and ball passing (if mobility is too much of an issue)
Honestly, I think the tunnels will end up being a bottleneck for many teams, so being able to go over the bumps will be big,
Also, being able to play both offense and defense will be huge, as two of the three sections will be primarily one or the other. I think for all the sections, being able to move balls quickly will be big, as you can effectivly play both offense and defense with a single move. The middle will be a combination of offense(being able to move returned balls) and defense(blocking tunnels) |
Of course, if I was a ref, I might call an <S01> violation if you were swinging, depending on the manner of swinging. Definitely if a tower came down. |
I'm wondering how these teams plan to shrink back to standard configuration before letting go. That's also rather important.
#10
I think a tunnel-dependent robot will be easily shut down. If the opposing alliance's star robot is tunnel-dependent, then your alliance can just take your weakest robot and stick it in a tunnel.
Also, I think pushing in the tunnel will be difficult with the high-up bumper positions. The force of pushing will be acting on your robot horizontally, and most likely above your robot's centre of gravity. So your robot will tend to lift the side it is pushing with, and may very well flip. |
#11
On one hand, herding a ball in any controlled manner would be very hard to do if you are going over the bump. On the other, going under means having to fight the 36inx18in space of the tunnel (29inx18in after you've factored out bumpers on the sides).
#12
Balls also roll through sometimes. |
#13
Vision / camera systems may be critical: We've started wondering (and won't know until we either build a Bump or CAD out the dimensions) if soccer balls will be easily visible across in the far zones because of the Bumps. If not, the ability for a robot to "see" will be critical, both on offense and defense.
#14
Building off of this, how long it takes a robot go get to the tower will play a role, seeing as that equates to more or less time that robot can attack or defend. Teams will have to decide if going for the tower will be worth it based on factors that will obviously change depending on the game.
#15
| What do you think the AVA topic will be this year? | Kevin Thorp | 3D Animation and Competition | 14 | 14-01-2008 17:31 |
| What do you think will happen....? | slickguy2007 | General Forum | 7 | 29-01-2007 18:39 |
| what do you think high score will be | nuggetsyl | General Forum | 13 | 03-04-2006 14:03 |
| What do you think this year's competition will be NAMED? | Elgin Clock | General Forum | 18 | 10-01-2004 19:35 |
| Do you think this years game will be... | Brian Savitt | General Forum | 26 | 09-12-2001 22:43 |
