Hanging robots and <G31>
What are some of your opinions on this rule, and my assumption that only one bar is viable for elevating your robot. |
Re: Hanging robots and <G31>
Look below the ball return in the official drawings. There's another bar there, below the ball return. If you can avoid hitting ball return elements while hanging on that, you can hang on any side of the tower.
As for not being able to hang on the sides, I can think of two robots that would be able to do that right off the top of my head, if they're still running: the 60/254 collaborative twins. They wouldn't balance on the bump, either. (Now that I've said this, watch those designs be copied all over the place...) |
Look at page 8 of the "arena section" in the game manual. It shows the ball return as being above the top of the tower, and no parts of the tower have black tape, so I think you can safely latch onto all four sides.
Good point. The side bar comment stands, though.
Agreed on the side bar hanging. There's numerous examples of side hanging robots from 2004. Take your pick of implementations.
I don't suppose you have a picture or care to explain how this mechanism would grab the side bar without balancing on the bump. edit: thanks Kevin, I will try to find some pics from 2004 as well as looking at the game. |
I found this image of team 60's robot from 2004, and unless I am looking at it wrong, the robot would have to be facing the bar to attach to it, and according to the comments the hook starts attached to their ball grabber with velcro and the ball grabber is in line with the wheel base. Also, the tower does not extend past the base of the hump, so that robot would have to be sitting on the bump, facing the bar to attach to it, or am I completely wrong here?
edit: theoretically if the arm was on the extreme left or right of the bot, and the hook was positioned perpendicular to the arm, you could drive OVER the bump with the arm extended and the hook would snag the bar as you drove by. ![]() |
#11
You're off. They'd go flying past the bar at close range with their gripper open and their hook pole out. Next thing you know, their arm is folded and they're climbing a cable.
Here's a link to a shot of starting configuration. It's the twin, 254, but it gets the point across. http://www.chiefdelphi.com/media/photos/18193 It was a sight to see... |
#12
the question i think youre asking is if you can hang on the cube shaped "tower" and the rule you have posted it for the return track which is the part above that the ball follows to get to the "tower and u cannot hang on that track at anytime during the match
#13
http://www.chiefdelphi.com/media/photos/17238
There's 57's. No problems lifting from the side,save that the window lift was a little slower than might have been optimal. |
#14
We're thinking about hanging off the virticle support posts on the tower. Our question is... Are the towers secured so they won't fall over with 130lb robot clamped on to one of it's verticle posts?
#15
A student just asked if the rules prevented us from shooting a grappling hook over the top of the tower and pulling us up with a cable.
| YMTC: Bluabot and Redabot hanging? | Natchez | You Make The Call | 15 | 23-03-2004 01:42 |
| 4 robots hanging | ECarlson | Regional Competitions | 3 | 08-03-2004 00:27 |
| Robots Hanging from the Floor | Todd Derbyshire | Rules/Strategy | 16 | 13-01-2004 14:10 |
| hanging off off other robots that are hanging off the horiz bar | Andrew Dahl | Rules/Strategy | 15 | 12-01-2004 19:14 |
| Starting position and hanging clarification | Don Wright | Rules/Strategy | 2 | 10-01-2004 14:21 |
