Go to Post To me, my mentors are the Father figures. They guide me through each and everything (even if its not robot related), and try to make it as fun as possible. - RoboMadi [more]
Unread 09-01-2010, 22:23
TD-Linux TD-Linux is offline
FRC #2530
TD-Linux is on a distinguished road
Lightbulb HOWTO: Install WindRiver on the Classmate over a network
I was able to install WindRiver easily on the Classmate (the netbook) by using the DVD drive of another computer. This only works on Windows, though you can probably find a different iSCSI server for the operating system on your computer with a DVD drive.
The steps I used were as follows:
  1. Download Alcohol 52% from here and install it on the computer with the CD drive.
  2. Follow the directions at Alcohol's web site to set up the shared drive and install Microsoft iSCSI Initiator on the Classmate.
  3. Insert the first DVD into your shared drive. Autorun should start on the Classmate automatically.
  4. In the installer, disable everything except for WindRiver.
  5. Install and activate Windriver per instructions provided with the DVDs. You'll need to swap out the DVD for disk 2 when prompted.
  6. When you're done with the install, make sure to disable the iSCSI target so the original computer's drive behaves normally.
  7. Remember to install updates from http://first.wpi.edu/FRC/frcupdates.html
Alternately, you could copy the contents of the two DVDs to sufficiently large flash drives (DON'T BE TEMPTED BY THE RECOVERY FLASH DRIVE). I didn't have any laying around, so I found the iSCSI method more convenient.
P.S. I typed this post on the Classmate - the keyboard isn't as bad as it first feels, but the ' key is in a really weird place.
Anyone install windriver on linux yet? keen101 Programming 34 10-02-2010 20:41
[BB] So, what about the Classmate? EricVanWyk General Forum 30 13-01-2010 20:04
how to install windriver!! mole Programming 4 30-12-2008 12:52
Can you install windriver on more than 1 pc? programmr Programming 7 12-12-2008 20:15
The *BIG* CMU Howto pi_guy578 Programming 17 21-12-2005 13:24
