Go to Post *gasp* robot? what robot? we were suppose to build a robot? - LightWaves1636 [more]
Unread 10-01-2010, 15:45
kirtar kirtar is offline
Alumnus
FRC #0461 (Westside Boiler Invasion)
Rookie Year: 2007
kirtar will become famous soon enough
<G39> Pinning
<G39> Pinning - A ROBOT may not pin (inhibit the movement of another ROBOT that is in contact with a field element, border, or goal) for more than 5 seconds. If a ROBOT has been pinned for 5 seconds, the team with the pinning ROBOT will be signaled by a referee to release the pinned ROBOT and back away approximately 6 feet. Once the pinning ROBOT has backed off by 6 feet for 3 seconds, it may again attempt to pin its opponent, and if successful, the 5 second count will start over. Violation: One PENALTY for each violation
First, I take it that the 5 second timer resets only when you back away for three seconds, regardless of how long you pinned the opposing robot. Second, if the robot is not touching a field element (I'm guessing floor excluded), it's not pinning, so you can push for as long as you want in that situatioin.
Also, if you are able to pin a robot indefinitely (e.g. tank pinning a killough drive in a corner), would you get only one penalty for this as long as they did not escape, or will you get one for every five seconds that you pin them for (kinda a stretch, but I can see someone using that interpretation)?
Pinning a Mechanism Rob2713g Technical Discussion 5 30-01-2008 13:11
Pinning opponents TRACKBALL popo308 Rules/Strategy 3 14-01-2008 22:07
Clarification on Pinning Stu Bloom Rules/Strategy 2 15-03-2006 05:07
Ramming/ Pinning f22flyboy General Forum 21 07-03-2003 20:39
Pinning the Goal DaringCommander Rules/Strategy 8 27-01-2002 11:57
