Go to Post Best. Team. Update. Ever. - Billfred [more]
Unread 10-01-2010, 16:11
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
Team Role: Coach
Rookie Year: 2007
frank.pendzich is an unknown quantity at this point
Ball Return
Can a robot block balls in the ball return so they can't make it to the field? Even knock them out of the channel to get control of them sooner.
Unread 10-01-2010, 16:13
kirtar kirtar is offline
Alumnus
FRC #0461 (Westside Boiler Invasion)
Rookie Year: 2007
kirtar will become famous soon enough
Re: Ball Return
Originally Posted by frank.pendzich View Post
Can a robot block balls in the ball return so they can make it to the field?
If I'm interpreting this correctly <G47> will answer your question
<G47> BALL RETURN Interference - ROBOTS may not interfere with BALLS in contact with the BALL RETURN. Violation: Two PENALTIES per affected BALL.
I hope you read the manual.
Unread 10-01-2010, 16:24
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
Rookie Year: 2007
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Ball Return
this brings up a question,
could you then stop your robot in front of the ball return and nock them back into your alliances zone right as they come off the track?...
you can only hang your robot in the last 20 sec. right?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 10-01-2010, 16:33
Alumnus
Rookie Year: 2007
Re: Ball Return
Any mechanism used to interact with the ball must be below the bumper zone or you will get a penalty every time you use it. However, if you for example, angled the top of your robot to affect how a ball would bounce off of the top of it, I don't think there's anything wrong with that.
Also, if you somehow manage to touch the tower without expanding beyond your normal configuration, you can hang any time you want without penalty, since being in contact with the tower allows you to expand to final configuration.
Unread 10-01-2010, 16:34
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
Rookie Year: 2000
Re: Ball Return
Yes, as long as they are off the ball return before they touch your robot.
I find nothing that states this.
(since 2004)
Unread 10-01-2010, 16:39
Locke64 Locke64 is offline
FRC #0063
Locke64 is an unknown quantity at this point
Re: Ball Return
Originally Posted by <G30>c
TOWER Contact ROBOT Volume - During a MATCH, ROBOTS in contact with their ALLIANCE TOWER may extend beyond their NORMAL CONFIGURATION volume but may not exceed the FINALE CONFIGURATION maximum volume.
It appears that you can hang from the tower and expand to the FINALE CONFIGURATION at any time during the match (unless there's another rule that I've forgotten). However, you are not protected by <G32> or <G34> from opponent contact.
That sounds like it could be a decent strategy, as long as you never gain POSSESION of the ball while it is in the air. (i.e. no chutes)
Unread 10-01-2010, 16:43
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
Re: Ball Return
My bad, I just reread the configuration rules and got a few words changed around
Adam Spears
Unread 10-01-2010, 16:44
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
Re: Ball Return
this is what I've been thinking, you could'nt really be defended upon since you are hanging...and it'd make scoring alot faster for your alliance..
Adam Spears
Unread 11-01-2010, 08:31
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
Rookie Year: 2010
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Re: Ball Return
Possession if defined as controlling the ball while you are in motion. If you are just hanging (or sitting) still, a chute, with no active mechanisms above the bumper zone, seems legal to me.
Unread 11-01-2010, 09:04
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Re: Ball Return
That is what I would think. Possession is defined as the ball remaining in relative proximity to the robot as the robot moves. If you are sitting in front of the chute, then the ball rolling off the robot is changing proximity and not being moved be the robot. You could look at this as the equivlant of a soccer player stoping a ball with their upper body.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 11-01-2010, 09:07
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: Ball Return
You can hang whenever you want from your own tower, but your robot is not protected until the last 20 seconds.
Hi!
Unread 11-01-2010, 09:19
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: Ball Return
Provided any expansion you do is while you are in contact with the tower.
Ball Return Trajectory kirtar General Forum 8 11-01-2010 08:07
Knocking off a ball while possesing a ball Joe Ross Rules/Strategy 25 10-03-2008 18:49
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 15-01-2008 23:27
Center goal ball return? b-rant FRC Game Design 12 22-04-2006 20:15
"Ball Return" mechanism... what is it? Randy_Ai Rules/Strategy 1 09-01-2002 16:12
