Re: Carrying <G44>
Oh, I want to know that too...
See: Quote:
Re: Carrying <G44>
1) You have the 5" wide bumpers to contend with first, so the idea of a wedge shape for shooting wouldn't be possible <R07-D> 2) If you then tried to get it up over the bumpers, you now also have the issue of <G30> Hope this helps! Welcome to FIRST! Best regards, Steve |
Re: Carrying <G44>
Seems like an upper surface on your robot made of memory foam to reduce bouncing, contoured and sloped such that balls hitting the foam will tend to land in front of the robot would be a good idea.
Since the robot is encouraged to be designed to not unintentionally carry balls, you have to have some sort of sloping top, might as well make it slope in your favor, and construct it of material in your favor. Or is this going to violate the rules? |
Re: Carrying <G44>
Re: Carrying <G44>
I had the same idea, although I was thinking of making it out of something slick just so the ball couldnt get caught (I like the dampening of the memory foam but I would be concerned about it potentially possessing the ball)
Here is my fairly crude drawing, but it should get the point across ![]() Other than making some sort of pyramid or convex surface Im not sure how else you prevent yourself from possessing a ball... (Remember if you do ask this in the Q&A dont use a specific robot design, just refer to the rules and ask questions about the rules themselves). |
Re: Carrying <G44>
Re: Carrying <G44>
In my opinion if you have something on top of your robot that could potentially carry the ball ( IE something with sides on it....) it will be considered illegal.
therefore if you decide on some type of chute system that IF your robot were turning when a ball is engaged by it and IF the chute would make the ball turn in the direction you are turning you would have an illegal mechanism. A simple slanted flat surface would seem to be ok given this approach. A u-shaped track or a flat surface with sides to guide the ball would not by the way I do really like the idea of referring to the balls as "possessed " Puts a whole different "dark" light on the game.... Good Luck and we will see you at the competition..!! |
Re: Carrying <G44>
Re: Carrying <G44>
But I'll agree, it is definitely something I wouldn't recommend doing until cleared by FIRST. |
| Carrying the message of first.... | OScubed | General Forum | 8 | 02-04-2009 19:44 |
| Trailer carrying capacity | Izeke0 | General Forum | 1 | 03-01-2009 23:49 |
| Ball carrying? | mad_cloversc | FIRST Tech Challenge | 5 | 01-12-2005 20:48 |
| Carrying Tetras | russell | Technical Discussion | 5 | 11-02-2005 14:21 |
| Question: Carrying Case | UIDzero | Technical Discussion | 10 | 10-11-2003 14:35 |
