Go to Post In my book the team building experience of the kids training the engineers in the operations on the field would be invaluable. It might not get a trophy but you win far more in the long run. - Wayne C. [more]
Unread 17-02-2010, 16:11
PapaRobocat PapaRobocat is offline
FRC #2161
PapaRobocat is an unknown quantity at this point
Re: Programming Mecanum
How do we program these wheels when they do not drive straight? In stupid terms cause I do not understand all the programming lingo.
Unread 04-04-2010, 23:00
jase728 jase728 is offline
AKA: Jase728
FRC #3210 (Falcons)
jase728 is an unknown quantity at this point
A good idea is to set up each motion (eg front or strafe) separately
then get the axis from your joystick this will get the magnitude
you will have to figure out the math
"In theory there is reality, but in reality there is no theory" - Erich Keane (FRC 2010 Build Season - Team 3210)
Unread 23-01-2010, 13:30
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by Daniel Jones View Post
The holonomic drive function will work with either mecanum or with a 4-wheel omni drive if the wheels are oriented 90 degrees from eachother, arranged like this:
on your diagram above for holonomic drive, when using mecanum wheels does it matter which way they are oriented?
Unread 27-01-2010, 18:41
Zrob Zrob is offline
FRC #1631
Zrob is an unknown quantity at this point
Ah, yes it works pretty well, except there's you gotta use
Code:
drive.holonomicDrive(leftStick.getMagnitude(), leftStick.getDirectionDegrees(), rightStick.getX());
holonomicDrive takes magnitude first, then direction.
One thing though: There's these weird delays, which I'm attempting to fix.
Unread 29-01-2010, 01:38
Imadapocalypse's Avatar
Imadapocalypse Imadapocalypse is offline
The Walking Contradiction
AKA: Bryce Ribucan
FRC #2443 (Blue Thunder)
Team Role: Leadership
Imadapocalypse is an unknown quantity at this point
Send a message via AIM to Imadapocalypse
Okay at this moment our programmers are working on trying to figure out the holonomic drive method. The motors are connected to the correct PWMs and we've been using the exact code given here in the forum but through our misfortune we have came up with the notion that the holonomic drive class has errors. Depending on what we do to our code the wheels will run in opposite directions, forward, or rotate; but never reverse.
We think it has something to do with the order of the parameters. Our programming works better if we put rotation where magnitude goes and vice versa. Direction is still much of a mystery.
As you can probably surmise from this entry our troupe of programmers are confused at this point. Right now our mentor is planning to copy the holonomic drive class in order to play with it to see if that yields any positive results.
The needs of the many out-weigh the needs of the few and the one
Unread 29-01-2010, 13:20
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Do you need to set the motors on one side inverted? When we first just tried we noticed the wheels on one side were reversed and we needed to add:
setInvertedMotor(RobotDrive.MotorType motor, boolean isInverted)
Mecanum Programming Help Mars Programming 8 27-02-2008 15:41
Bizarre Mecanum Programming Bug manderson5192 Programming 10 08-02-2008 22:11
Mecanum drivetrain programming problems Mr. Freeman Programming 4 21-03-2007 17:11
mecanum programming mrmummert Programming 27 28-01-2007 13:45
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
