Go to Post If there is anything I have learned from ChiefDelphi, it's to never underestimate the coding genius that is Brandon Martus. - Amanda Morrison [more]
Unread 10-01-2010, 18:38
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Imaging Tool does not find cRIO
Our cRIO has last year's run time and code on it.
This year's imaging tool does not find the cRIO when I try to reimage the cRIO with this year's run time.
I can ping the cRIO, but the imaging tool will not recognize the cRIO.
I tried to deploy a program built with Labview 8.6.1 and got an error that the run-time was not compatible. This indicates that the cRIO will talk back to the labview.
Thanks
Code deploys but does not save to cRIO Bill Taylor NI LabVIEW 11 15-02-2012 20:30
cRIO Does Not Communicate, Yet Can Be Pinged and Re-Imaged 1951-44U FRC Control System 7 15-12-2009 21:25
Problem with cRIO Imaging Tool Doc Wu FRC Control System 7 15-12-2009 19:47
cRIO Imaging Tool HELP PLEASE!!! furiousgeorge FRC Control System 2 08-02-2009 22:44
FRC cRIO Imaging Tool furiousgeorge Programming 1 06-02-2009 09:52
