Re: Sideways Hanging - Yes or No
Don't be too sure of this. The pole is in bending (shear) while the robot is in compression/tension.
Think of it this way, force applied to the vertical support is applied parallel to the floor, but the weight of the robots is applied perpendicular to the floor. This is assuming a design like the original posting. |
The top left one should say either forums or portal: If it says portal then click on it and it will take you to the portal anf the top left one will then be forums. When it says forums, click on it ... that'll take you to the forums list. Then click on the forum you wish to add your thread to. Once there there will be a blue button that says new thread (looks like the post button) |
I do not believe it is our job to guess what the GDC intends. If there is no rule explicitly stating you cannot hang from it, it would appear you can. |
On the other hand, if the tower isn't strong enough to hold a robot hanging sideways (though I personally highly doubt it) than obviously that wasn't an intended part of the game, and if the tower breaks, it's breaking a ton of rules.
One thing I learned is never take any strategy for granted, until FIRST specifically say you are allowed to use it. I have seen a few robots too many that were built, shipped, and had to be completely rebuilt at the regionals, many of them with innovative strategies that came as a surprise to the GDC. |
A preliminary Inventor model suggests that a 150 lb robot with a CoM 18 inches off the center of the pipe will load a single pipe to 50% of yield.
This is using the cheesy "Stress Analysis" Inventor package we get with the kit, so it's somewhat less trustworthy for the coarse mesh it's limited to. But it's also assuming the pipe is a cantilevered column with support only at the bottom, which is clearly not the case. The rigid connections to the other side of the tower will mean some load will be carried through the top of the pipe as well. So I think one robot per vertical pipe is a reasonable load for the tower. However.... I was assuming a 12 inch separation between the "hands". The hands generate two equal and opposite forces to create a moment to balance the moment generated by the robot's CoM. The closer the hands, the greater the point force required to generate this moment. At around 6" of separation, this point load starts to become significant. At this point you have to worry about crushing the pipe between your hands in addition to bending the pipe at the base. This crushing type failure will NOT be improved by rigid connections at the top and middle of the platform. The only way to improve it is to increase the separation of your hands. Something for to think about for teams considering this approach: This normal loading on your hands increases linearly with the weight of your robot(s). And you can customize magnitude of this normal force by choosing the separation between your hands. I wonder how this could be useful..... |
Definitely something to consider. |
To address some posts that came up while I was playing with inventor, if you're planning on supporting the entire moment of your robot at one rotary joint... Well good luck to you. 225 ft-lbs is pretty significant for a single joint to support. Also, as I thought my post made clear, don't assume that the tower is indestructible. It is certainly rather sturdy, but it's not nearly as reinforced as it could be. Front-to-back loads will mostly be carried by the joint at the base, with only a little load carried by the frame at the top. So.... I think it's safe(ish) to hang a robot off the side of the tower, but I don't recommend bouncing or anything when you do it. |
#10
Have you interacted with the actual field elements? The tower is pretty rigid in my opinion. The steel piping that is used is very rigid. I would make sure you fully explore this option before determining the vertical member will be stressed beyond yield. -Brando |
#11
The tower is very rigid. At one point at the NH kickoff there were three kids hanging on it, and not gingerly.
Its really hard to tell from the photos/drawings, but there are solid metal plates below the tower & the bumps that help keep them solidly in place. They are mentioned in the rules: Quote:
#12
I guess my big concern is the column in compression and then a bot hanging sideways as mentioned shock loading that column in bending. Plus if the bot is hanging out like that and maybe sticking out 4', then another bot climbs on the back of bot 1, or even 2 bots. That could put the bots collective cg as much as 4'-6' away from the side of the tower. That's a lot of force on that 1 column that's now in compression and bending. bad.... And if the collective cg gets out past the edge of the floor plate in any direction it could pull it over.
#13
-Brando |
#14
Is whatever mechanism you will use to grab able to be released without power?
#15
I would not let concern about the tower post failing or tipping over stop you from pursuing this or any other climbing method. The field apparatus is designed to take whatever methods the challenge has invited. If you are clever enough to do this, go for it.
| Sideways Driving | zzz | Rules/Strategy | 8 | 08-01-2008 01:37 |
| Mounting the ES17-12 sideways orientation | SuperBK | Electrical | 10 | 21-01-2007 09:38 |
| Sideways vs Forward Speed of Mercanum | ggoldman | Technical Discussion | 1 | 20-01-2007 11:06 |
| Can the Cameras be mounted Sideways? | vicecityman666 | Technical Discussion | 1 | 29-01-2005 10:21 |
| Sideways mounting | srjjs | Electrical | 13 | 25-01-2003 20:31 |
