Go to Post Soon, some of those teams will learn to rise about current and former powerhouses. - Akash Rastogi [more]
Unread 13-01-2010, 12:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Sideways Hanging - Yes or No
Yes, go for it, but before you get too far along, you might want to make sure it will not cause damage to the TOWER.
Unread 13-01-2010, 12:50
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
The pipe should kink before the tower tips over. A word of warning though. You kink the tower pipe, consider how long it will take to disassemble the field and find a replacement pipe (it's likely there will not be a spare shipped with the field, meaning shop time) and reassemble the field. Then consider how many teams are waiting, and that they know you are why they can't play.
Do math.
Wetzel
Viva Olancho!
Unread 13-01-2010, 13:04
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I'm sure anyone designing this type of hanging would wanna have a wide grip anyways... and the wider the grip on the bar, the less likely the bar would bend or break.
Our team has talked about this hanging method and started design a system with a 28" wide grip. Far more then what was calculate by Kevin
EDIT: our system is similar to the boy on the bar, but uses mechanical leverage and should be much much safer then a "hook and lift" method
Unread 13-01-2010, 13:02
kshin18 kshin18 is offline
FRC #3017
kshin18 is an unknown quantity at this point
its going to be difficult hanging sideways since rules state the robot has to be hanging 12 inches off the ground and side ways would require more lift
Unread 13-01-2010, 13:05
Wetzel's Avatar
DC Robotics
Rookie Year: 1999
For SUSPENDED or ELEVATED robots? Can you cite what rule you are talking about? Not to mention that 12 inches is 12 inches, no matter how you lift. (And 12 inches is not the 18 to ELEVATE)
Wetzel
Viva Olancho!
Unread 13-01-2010, 13:20
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Rookie Year: 1999
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
To re-iterate my point of having a 250lb + cg that's as much as 4-6' away from the SIDE of the tower. If you have a 130lb bot 4' tall but in horizontal position (Meaning your base has over 120 lbs in it and its suspended 4' from the side of the tower) Then another bot hooks on to your base adding another 130lbs and also shifting the cg even further from the tower (then possibly even a 3rd bot hooks on), I can almost guarantee the tower will fall over and it could bend the pipe depending on design and how the bots climb on (bouncy etc.) I doubt the tower structure weighs more than 50lbs and only has an 18" plate sticking out? But 250-370lbs of bots hanging 4+ feet away will topple it. I'll be surprised if they don't nix the idea. Maybe I'm wrong.. we'll see...
www.179swampthing.org
Unread 13-01-2010, 13:36
FRC #1360
The Q&A is now up. Can anyone ask about this? I cannot because I do not have access to my teams "official" login.
EDIT: One thing that I forgot to mention, its would be much harder to topple the top if you hanging sideways at a low elevation (just about the platform say) also, the platform would supply an increased resistance to bending and breaking the bar. I think this is totally doable
Unread 13-01-2010, 13:42
Wetzel's Avatar
DC Robotics
Rookie Year: 1999
What would you like asked? Hanging off the side is allowed, no one is debating that. If you ask if it will damage the field, the response is going to be "we can't comment on specific designs" or "if you break the field we break you."
Wetzel
Viva Olancho!
Unread 13-01-2010, 13:47
FRC #1360
"Is the tower strong enough to support the weight of three robots hanging from a vertical bar as oppose to the standard horizontal bar?"
and asking them if your allowed to hang off the vertical bar is a completely good question to me.
Unread 13-01-2010, 16:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
The platform does not provide any structural reinforcement to the tower. It's a wooden box that rests on the tower's base plates with no connection to the vertical pipes. So don't expect that to save the tower.
Wetzel
18 inches isn't the 20 inches needed to elevate either. Don't confuse the tunnel height with the platform level.
I will agree with you that hanging lots of robots off of other robots can be a dangerous endeavor in many ways. I'm having difficulty believing that anyone is going to design a robot that is capable of suspending 250+ lbs of robots at a 6' lever arm from the side of the platform. That's a very serious moment to put on any part of one of our robots.
More to the point, I'm seriously doubting that you can flip the tower before you fail the vertical pipes. Flipping the tower is going to require applying that huge moment to the tower somewhere. Which is going to be transmitted through the vertical pipes. Which are going to break if you put that kind of moment on them. Plus, there's the ball return which is going to resist your efforts at flipping the tower. So... I think worries about flipping the tower are a bit less immediate than worries about breaking it.
Unread 20-01-2010, 08:47
Swampdude's Avatar
AKA: Dan Quiggle
Rookie Year: 1999
FYI
Guess that means we're good to go!
Unread 20-01-2010, 09:24
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Rookie Year: 1999
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
FYI
Yup! My only question is, in the event of damage (gripper causing damage to the pole, 3 robots hanging at the same point causing damage to the structure, etc), who is responsible?
Let's say the teams hanging all went through reasonable measures in preventing their robots from creating excessive forces and causing damages while hanging. In the event of a tower failure, is it FIRST's responsibility to make the tower stronger, or is it team's responsibilities to change their design such that failure will not occur again (like redesigning to hang from the horizontal bars)?
Interesting thing to think about.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 20-01-2010, 09:54
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
I think a team that is going to do this is not so much thinking about holding other bots,but that they can hang from their home zone and open up more space for other teams. If this team can climb in 10 seconds they would be able to score up to that point, then head over to the pole. Now does the other team leave a defender back or does he leave early to hang. Oh, so many variables this year.
Unread 13-01-2010, 13:39
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
I'd agree that if the rules don't prohibit it, it is allowed, but I'd hate to spend a lot of time designing, building and perfecting it, just to have it thrown out by a rules clarification in week 5 of build.
It wouldn't surprise me to see that happen, especially if there was concern about damage to the field.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
  #15   Spotlight this post!
Unread 13-01-2010, 16:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
This is the specific scenario I'm worried about. You could in theory have one SUSPENDED robot (call it a Blue Alliance robot), outside of the tower, say on the midfield side. Then another blue robot hanging off of it (toward the red side), than yet anotherblue robot hanging off of it, toward the red side. At potentially 465 lbs, this is getting to be a somewhat large cantilevered load, imposing a fairly large moment on the tower structure. Perhaps the ball return would keep the tower from toppling? Is it tied in? And remember, it's not just the weight of these robots. There is extra force required to accelerate them to these positions, and overcome stuck conditions that may occur.
Sideways Driving zzz Rules/Strategy 8 08-01-2008 01:37
Mounting the ES17-12 sideways orientation SuperBK Electrical 10 21-01-2007 09:38
Sideways vs Forward Speed of Mercanum ggoldman Technical Discussion 1 20-01-2007 11:06
Can the Cameras be mounted Sideways? vicecityman666 Technical Discussion 1 29-01-2005 10:21
Sideways mounting srjjs Electrical 13 25-01-2003 20:31
