Is it legal to have more than one shooting mechanism (ie. one on the front and another on the back of your robot)? I looked throgh the rules and couldn't find anything against it, but I may not have seen it.
Re: Multiple shooting mechanisms
There should not be a problem with having multiple "shooting" mechanisms as no rules specifically limit the number of functional components on the robot.
Nothing in the rules prohibits this.
I thought you could only have possession of 1 soccer ball at a time
I would think that it would be helpful so you could get a ball without having to turn the robot around, it would increase the speed at which you could play the game.
not to try to play with two balls at once! |
The only issue with the rules would be if you did it to shoot faster than once every 2 seconds
So to answer your thought or question yes robots may only possess 1 ball at a time but that was not the question. karatekid was wondering if it was legal to have multiple shooters dosn't mean 2 balls will be in possession at the time. Probably for strategic purpose's. |
According to G30 does this mean that each mechanism can only shoot every 2 seconds, or that once one mechanism breaks the frame perimeter that no other mechanisms can do so for 2 seconds?
#10
Your good to go with this, but while I'm here I thought I would suggest something 1930 did in 2008. Are main idea was that you could save time by not turning and instead backing up when you got to the other end of the field, to aid in this we set up two buttons on top of the joysticks that would reverse the forward direction on the joystick to instead move the robot backwards. This means that if you have a ball behind you during the game you can just press a button and it will reverse the robots direction, to some this may seem trivial, but it helps you make better sense of the direction your going in and is more comfortable than just going backwards.
#11
yes, at least to my interpretation
#12
If one of these mechanisms acted on multiple balls would it be considered possessing them? I am unclear if kicking i considered possession. The intent of the rule seems to be to stop teams from hoarding balls not stop them from kicking many of them. Any thoughts?
#13
I don't think that was a yes or no question...
#15
| [FTC]: Multiple Programs or One Program with Multiple Auto Modes | kevin51292 | FIRST Tech Challenge | 4 | 02-01-2009 20:37 |
| Hosting multiple sites in multiple VMs | EHaskins | Website Design/Showcase | 6 | 22-12-2007 01:09 |
| Tetra Grabbing Mechanisms | DAN THE MAN | Technical Discussion | 2 | 15-01-2005 21:15 |
| Tires & Mechanisms | tenfour | General Forum | 2 | 27-01-2003 03:00 |
