Re: Effective Drive Base
The kit bot rolls over the bump with ease because of the large wheels, it does not bottom out on the top of the bump. However, turning with 4wd is a pain. The robot "jumps" as it counters the friction while turning with skid steer.
I’ve confirmed this both in CAD and testing. Of course you can mount the T-boxes on top of the frame, and solve this problem. Interesting design feature AM... ![]() |
We are most likely going with 8 with the front sets raised slightly, I think it will be a common design among experienced teams. |
Could 4 wheel crab steering make it over the bump?
Our team is looking into either that or standard 4 wheel skid steering. |
I would love to see a version of 2004-71 style swerve.
Is this possible with the BUMPER ZONE rules as they are? Would articulating your wheels change your BUMPER height?
This is the reason I ruled it out as a possible design. Bumpers ruin everything.
We need to remember that the bumper zone is elevated this year, 10-16 inches above the floor when on a flat surface and may not be articulated.
8.2 DEFINITIONS BUMPERS – Bumper assemblies designed to attach to the exterior of the ROBOT within the BUMPER ZONE, and constructed as specified in Rule <R07>. BUMPERS are excluded from the weight and volume calculations specified in Rule <R10>. BUMPER ZONE – the volume contained between two virtual horizontal planes, ten inches above the floor and sixteen inches above the floor. <R07> A. BUMPERS must provide complete protection of the entire FRAME PERIMETER of the ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT). The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor, and must remain there (i.e. the BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE). If one uses 6 inch wheels, then the drive assembly would need to be a good distance behind the frame perimeter for any bumper to interfere with climbing. (The top of the bump is 12 inches high but also 12 inches set back from the base) This does not appear to rule out any type of drive system that would take into account the shape and height of the bump. As to whether a crab drive would succeed on the bump over a different drive system is up to the team to prototype and then make a decision. As is discussed in several other places, high center of gravity seems to be the more important issue if choosing to climb the bump. Considering all of the factors summed together, it appears to be a considerable challenge to design a robot that both climbs over the bump or drives through the tunnel. |
#10
My team has been doing some testing to see which drivetrain handles the bump best when driving over it at an angle (we assume that we won't be able to hit the bump perfectly straight every time). We have prototyped a few ideas, including 8WD with raised end wheels. Has anyone else considered how their drivetrain will work when driving over the bump at an angle (or if their robot gets hit when driving over the bump)?
#11
Try actually adding some mechanisms to that kitbot frame. The COG is so high that it gets scary pretty quickly. We've done a lot of testing the last couple days, and 6 wheel bots long, 4 wheel bots wide, and even 6 wheel bots wide are all pretty darn scary on that bump - the smallest twitch makes them flip over. We're moving on to more exotic drive systems =). You absolutely CAN NOT decide on a drive train without at least building a small trial-bump to play with and see how your bot is going to react.
#13
We didn't test any of those, our first prototype is 8wd. I sure hope it works! We had to figure out what wheels to use on it, then order them, so we won't have it going for a couple more days
#14
We put some old 6" rover and Bayer kit wheels on the 8wd chassis, and rolled it over the bump (human powered, not motor powered)....looks pretty good so far. Nothing too scary.
Hopefully we'll get the drivetrain and electronics going and drive it over by Friday. |
#15
I think that treads provide too high a probability of falling off the bot on turns. I think the grip wheels that came with the kit are the best option
| pic: drive base idea | dbell | Extra Discussion | 23 | 26-07-2008 11:11 |
| pic: DeWalt drive base | dbell | Extra Discussion | 16 | 18-09-2007 17:10 |
| pic: 195 Drive Base | Tom Bottiglieri | Robot Showcase | 24 | 16-02-2006 12:50 |
| pic: 1083 drive base | CD47-Bot | Robot Showcase | 11 | 24-02-2004 14:04 |
| Drive Base Advice | archiver | 2001 | 0 | 23-06-2002 22:57 |
