Go to Post "How do we make our team be like your team?" That's the sort of question everyone should be asking of these so-called "elite" or "powerhouse" teams. - sanddrag [more]
Unread 13-01-2010, 16:53
DarkAndroid's Avatar
DarkAndroid DarkAndroid is offline
FRC #2014
DarkAndroid is an unknown quantity at this point
Re: Effective Drive Base
Hey I have a question:
Do anyone have any idea to build swerve drive wheels?
Our team needs help designing the wheels and distributing the power from the motors.
I hope anyone can help and i cant wait till i see you all come to my hometown of the St.Louis regional!!!
Unread 13-01-2010, 17:54
CraigHickman
Posts: n/a
I would recommend looking at the WildSwerve (look at the Andymark website) if you're interested in doing a swerve. However, if you aren't confident in the design principles behind a crab, I would not recommend undertaking it this late in the season.
Unread 13-01-2010, 18:29
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
There seems to be a lot of mis-communication and conjecture in this thread. I would suggest you simply build the kit bot using the wheels that came in the KOP and make a determination from that experiment/prototype. Each type of drive carries it's own set of pros and cons and risks for this game. Tank treads will climb but can cause excessive (near stall) current in turns if not implemented properly. Crab drive can be hard to control and requires a ton of practice to get it right. Drive systems that have a low COG on the floor may not have the same stability when crossing the bump. Prototype and then let the team decide which drive seems to work for the strategy and brainstorming you have (should have) done.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 15-01-2010, 20:37
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
they're out of stock
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 16-01-2010, 15:12
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
the WildSwere will not work going over bumps because there is a plate that is about 1" above the ground, and will get stuck on the bump before the wheel can make contact. My team is doing 6wd because of this problem (and our programmer doesnt want to have to figure out a swerve drive in 6 weeks)
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 16-01-2010, 17:07
Modified modules + modified and creative frame.
Unread 16-01-2010, 19:47
CraigHickman
Posts: n/a
I never said a Crab would be a good idea, nor that it would make it over the ramp. It would be possible to make a crab that can climb. Heck, it's FIRST! Teams have proven it's possible to make almost anything!
Unread 14-01-2010, 08:00
edison edison is offline
Edison 73
FRC #0073 (VISIONEERS)
Team Role: Teacher
edison is an unknown quantity at this point
can you tell me how to post cant find it we are registered and all
thanks
Unread 14-01-2010, 09:48
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
thanks
Post what, and where? Obviously you've figured out how to post on ChiefDelphi.
(since 2004)
Unread 14-01-2010, 12:26
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
thanks
Edison,
I've seen you post this same question in at least four other threads. It is usually bad form to ask the same question multiple times, especially in different threads. I've seen your question was answered multiple times. Are you still having issues?
pic: drive base idea dbell Extra Discussion 23 26-07-2008 11:11
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
Drive Base Advice archiver 2001 0 23-06-2002 22:57
