Go to Post FIRST is supposed to prepare you for a focused career in your subject of interst, and help you manage your time and resources effectively. - Eugenia Gabrielov [more]
Unread 29-01-2010, 21:22
Damiles Damiles is offline
FRC #3389
Damiles is an unknown quantity at this point
Re: Wheels?
Hi. I'm a totally confused rural rookie. My question similar to this one. I actually did read section 8 several times and everything else my glossed over eyelids could handle on the subject. Its just that one rule says EXACT KOP replacements are required. And other rules infer that its ok to use other COTS parts on the robot.
"If we use a different wheel from the KOP that doesn't fit inside the wheel housing? Can we use a different wheel housing? Or could I maybe modify the KOP housings to fit over the wheels because I'd like a different sized tire?"
I've seriously looked everywhere... and from what I gather, I can use a different wheel housing as long as its basically safe.
Unread 29-01-2010, 21:34
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Wheels?
Damiles,
KOP wheels are not required. You may use them but you may use others as well. The rule in Section 8 <R08> relates to things that cannot contact the carpet which leaves a whole world of wheels at your disposal. Can you remember which rule you read that made you believe KOP wheels were the only thing you could use? Is it possible you were reading the 2009 Robot rules? Last year you had to use the wheels that came in the KOP or additional wheels of the same type.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-01-2010, 00:31
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
Re: Wheels?
correct, there really are no restrictions on wheels, except that they can't damage stuff
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 11-01-2010, 10:00
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: Wheels?
Check section 8 of the manual. There are no* restrictions on the wheels this year.
*Meaning that as long as your wheels are not made of dangerous materials and no metal touches the carpet you are probably ok. (R02, 05, 08 etc) But PLEASE double check with the rules.
6 wheels with only 2 powered wheels bhsrobotics1671 General Forum 15 14-01-2008 17:28
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
