Go to Post Compact gearboxes are a wonderful thing. - Cothron Theiss [more]
Unread 11-01-2010, 13:37
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Changing bumper colors
<R07>:
H. BUMPERS must be designed for quick and easy installation and removal, to aid in weighing and inspection (as a guideline, BUMPERS should be removable by one person in less than ten minutes).
But,
<T13> At the conclusion of a MATCH, all players shall remain in their assigned locations until the Head Referee issues the “field-reset” signal. Once the Head Referee issues this signal, the 3-minute “match-reset” period will begin. The ARENA must be cleared of ROBOTS from the MATCH just ended, and the ROBOTS and OPERATORS CONSOLES for the following MATCH must be placed in position and ready to start before the expiration of the “match-reset” period. Field Attendants will reset the ARENA elements during this time.
And,
<T20> During the elimination rounds, if circumstances require an ALLIANCE to play in back-to-back MATCHES, they will be granted an additional minute of set-up time to reset and allow their ROBOTS to cool down.
(all emphasis mine)
Sometimes during the eliminations, alliances switch from being red to blue or vice versa, and have to play back-to-back. You'd better be able to change your bumper colors in 4 minutes or less.
(since 2004)
Unread 11-01-2010, 13:43
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Re: Changing bumper colors
I recommed ball lock spring pins. Zero to bumper in 15 seconds.
http://www.mcmaster.com/#pins/=5bx5nm
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 11-01-2010, 13:45
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Originally Posted by GaryVoshol View Post
<R07>:
But,
And,(all emphasis mine)
Several times during the eliminations, alliances switch from being red to blue or vice versa. You'd better be able to change your bumper colors in 4 minutes or less.
Are you fishing for questions? Such as, what if we build two sets of bumpers, one red - one blue? Would they have to be weighed in together, and weigh less than 20 pounds combined?
Unread 11-01-2010, 13:51
In the rules <R07> they clearly say you can have 2 sets of bumpers at 20 lbs each. IMO take advantage of the rule and make 2 sets and do a quick change.
Thank-you 294 & 67
Unread 11-01-2010, 13:54
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
No. He's saying that bumper color will need to be changeable within 4 minutes because of the field reset rules.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 11-01-2010, 14:40
iqjavier's Avatar
iqjavier iqjavier is offline
FRC #1591
iqjavier is an unknown quantity at this point
These new bumper changing things are going to be pretty neat.
Unread 11-01-2010, 14:45
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
<R12 B>: The BUMPERS may be constructed with a fabric covering of one color (see Rule <R07-F>), and then covered with a removable fabric shroud of the opposite color when appropriate. (snip)
The kickoff video showed the use of a removable bumper cover - see it at 5:36 in this video.
Pete Kieselbach
Unread 11-01-2010, 14:50
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Yes, but <G46> says, "a. Bumper covers must not detach, even unintentionally, from the ROBOT. Violation: PENALTY." That cover in kickoff didn't look like it was robustly attached.
(since 2004)
Unread 11-01-2010, 15:15
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Elimination rounds are often played back-to-back but they are usually within the same bracket level and alliances never switch colors within the same bracket. The only time this would be an issue is if you were the last group to finish a given bracket level and were in the first group of the next. From my experience, they draw the time out between elimination bracket levels a bit since at least one alliance in the next level would have had at least one round of rest and the other may or may not have.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 11-01-2010, 16:11
kjolana1124's Avatar
kjolana1124 kjolana1124 is offline
AKA: Kelsey Jo Starr
FRC #1124 (The ÜberBots)
Rookie Year: 2007
kjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant future
This might end up playing a role in driver and/or pit crew selection. Kind of like battery management. I wonder how strongly they're going to be enforcing this rule, seeing as there are often field issues and whatnot anyway
Woodie Flowers asked for Super Nerds
We're giving him ÜberNerds
~Tweeeeter~
2010 Northeast Utilities Hartford Regional Champions
2010 WPI Regional Chairman's Award Winners
2008 Hartford Regional Champions
Unread 11-01-2010, 16:24
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Has your team used this or is it just an idea? If used, how many on, let's say, the long side? How well did it hold up during the season?
Unread 11-01-2010, 16:54
We used 6 (six) to hold on all bumpers last year. One at each corner and one on the inside of each short section across the font. Also our bumpers were essentialy continuous fabric around the perimeter to help.
I think no more than 2 a side are necessary and if you use the same one in the corner to hold 2 sides as we did last year 4 total is all you need this year.
Thank-you 294 & 67
Unread 11-01-2010, 17:36
Rookie Year: 2007
We've used these for a few years now. We tend to use three on each long side.
~Tweeeeter~
Unread 11-01-2010, 17:38
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Team Role: Mechanical
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
I think it is going to be a pain in the butt...
I dont like the fact that we have to change such a large component of our robot to indicate our team color. I kind of wish that they would do something else for that purpose.
In the past, our teams bumpers have been pretty much permanant...The only times we ever had to take them off was to weigh the robot, and to get it to fit into the crate for shipping...
Now we have to change them almost every match? that just seems a bit rediculous...
I COMPLETELY do not trust bumper covers. They seem too easy to remove, no matter HOW you design them...I dont think that capability is worth the chance of a penalty
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
  #15   Spotlight this post!
Unread 11-01-2010, 18:14
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
does anyone know which blue is required for the bumpers?
I called Seattle Fabrics and they have 2 types: Royal and Navy Blue.
Im thinking it doesnt matter, but just wanted to make sure.
When we asked, teams that called earlier didnt know and they themselves have not been told by FIRST if it had to be a specific one.
Dont want to base it from the video and the video alone.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Camera Colors ExarKun666 C/C++ 7 21-03-2009 16:24
Camera colors Anton Programming 3 09-02-2005 14:13
Paint Colors? SPARKY1688 General Forum 1 02-02-2005 22:17
Colors doyler Programming 2 30-01-2005 15:22
LED colors archiver 2001 1 24-06-2002 00:04
