Go to Post Why did they get rid of the headphone jack though? =p - sportzkrazzy [more]
Unread 11-01-2010, 17:16
Aaron S's Avatar
Aaron S Aaron S is offline
FRC #1612 (Robosharks)
Aaron S is an unknown quantity at this point
Send a message via AIM to Aaron S
Windriver - Cannot Create New Example Project
Every time I attempt to create a new example project in Windriver (2010 from the new DVDs, fresh install on a system that has never had it installed before), I get this error. As far as I know, I followed all the steps in the manuals and installed all the necessary updates, and yet I still get this error every time I attempt to create a project.
Help?
Unread 11-01-2010, 17:45
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Re: Windriver - Cannot Create New Example Project
Looks like it is choking on the space in a path component (c:\Documents and Settings is stopping at Documents).
Did you install Windriver to a location other than the default c:\WindRiver?
Is your workspace someplace other than the default of c:\WindRiver\workspace?
If so, what happens if you try moving one or the other to the default location?
Unread 11-01-2010, 18:25
Aaron S's Avatar
Everything is defaulted. The install directory is C:\Windriver, and the workspace is C:\Windriver\Workspace (notice the capitalized W's). Last year I installed all of this the same way in a virtual machine on my Mac OS X partition and it worked fine, so I'm not sure what the deal is.
Unread 14-01-2010, 03:29
Aaron S's Avatar
Can anyone offer any advice? I can't get started programming until this issue is fixed.
Unread 14-01-2010, 14:54
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Are you running on a mac now? is this with Parallels or VMWare?
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 14-01-2010, 17:15
Aaron S's Avatar
No, this error is popping up under Windows XP while running natively on a separate partition.
Unread 19-01-2010, 21:25
AKA: Brad
Aaron -
Have you been able to get this working?
Brad Miller
Default Labview Dashboard and Windriver Example Help sircedric4 Programming 7 25-02-2009 01:58
help:Downloading the project in windriver mahmosh C/C++ 5 10-01-2009 10:08
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Arizona gets half million to create new teams! falconmaster General Forum 20 04-11-2007 23:00
Can anyone create new commands? Jakenan Programming 5 22-01-2005 21:38
