Re: Mecanum Drive Killing Battery
I've used Mecs except 2009.
I would also look and see whether each axle is in alignment with the other ones in a TRI-dimensional environment. Remember that Mecs run on the idea of vectors and so when these vectors are off, the stress on the wheels will increase greatly. I also point out that if you are testing the rubber rollers (plastic less so) on carpet, the frictional force applied to the out-of-line wheels is exponential. Also, try doing some stress-tests and full power cycles on your battery (don't hurt yourselves!). Batteries aren't built for a strenuous 4 weeks and then mild-no work for the other 48 weeks. (Ahh chemistry.) If you use Mecs and you can't go to a machine shop, I highly recommend using the supplied chassis with little to no personal drilling. Vectors are fickle! |
We have used Andy Mark 8" Mecanum wheels, direct drive on Andy Mark Tough boxes in 2008, 2010, and we will use them again ths year. If you are killing your battery it is not the fault of the wheels. To sum it up they work great.
A mecanum drive is less likely to "kill your battery" than a traction drive, but even running a very high current single speed traction drive last year we would always make it through a match with 4 CIMs, 2 FPs, and a compressor running. Our batteries left quite low (maybe a second match was possible, probably not) but we made it just fine. |
| crab drive vs. mecanum drive system | superbotman | Technical Discussion | 33 | 06-01-2010 03:09 |
| Mecanum Drive - Help | Smoking_Gun | Programming | 22 | 04-12-2007 20:51 |
| Mecanum Drive Technique | Dan Petrovic | Technical Discussion | 9 | 16-08-2006 20:42 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
