Go to Post there is no such thing as too many offseason competitions. - Berserker [more]
Unread 11-01-2010, 23:10
techwizrd techwizrd is offline
Autonomous Programmer
FRC #0116 (Epsilon Delta)
techwizrd is an unknown quantity at this point
Send a message via AIM to techwizrd
Compiling on Linux
Almost all of the programmers on our software team run Linux and use editors like Vim, Geany, etc. As far as I know, Wind River Workbench on Windows and is the only supported method for compiling C++ code to the robot. Is there a Makefile we could use instead?
Controls/Software Autonomous Programmer for Team 116
Epsilon Delta For The Win!
Unread 12-01-2010, 06:33
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Compiling on Linux
Yes and no.
If you started now, trying to establish a viable build environment on Linux, you might get it right in time for the 2011 season.
Workbench has a VI mode editor though.
Also, WB installs many UNIX-like utilities that can be accessed from the development shell.
Unread 12-01-2010, 21:59
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
Rookie Year: 2010
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
i asked my friend who mentioned something about g++... not sure if it will make robot compatible code, or if it just makes linux excutables...
Unread 12-01-2010, 22:10
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
There is no reason why you can't do all of your editing in vim, emacs, etc. (after all, they are just text files on the disk). Then, use Workbench to do compilation and deploy the code. You could either install Cygwin on a Windows machine, or get WindRiver running on WINE for this to work.
Unread 12-01-2010, 22:24
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
GCC/G++ can build for just about anything, including PowerPC (what the cRio is), although I doubt a plain PowerPC build will work on the cRio, plus the WPIlib will probably not like not being run through its normal compiler.
Have you tried running any of this on WINE? Then you can edit the files as you wish, then compile them in a sorta-native-running WindRiver (since Wine does not actually emulate, it is much faster then emulators/visualizers).
Another option you have is to use a SVN or similar repository server and then have a computer running Windows with WindRiver dedicated to building stuff and loading it to the cRio (possibly your Classmate.) This would also give you a central repository for all of your code, which would help with versioning and out-of-date code in builds.
It would have been better to start before kickoff. You should still be able to get it done in the next few days.
Kettering Motorsports
Unread 13-01-2010, 05:00
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
We compiled and downloaded under Linux last year using WINE, and will this year. I started in on getting debugging working, but backed down. Download the windows tools at the following URL, and extract them to the spot listed in the Makefile. The makefile should then download WPILib (last year's version, you can easily see where to specify the new source), patch it, and then compile it. I also included the patches I wrote to get doxygen to work to my satisfaction with the downloaded version of WPILib, and to get the Makefile for WPILib to actually work. Remove the .txt extension, and make a directory called bin where you are compiling, and put the patches there. It should be slightly obvious from the Makefile. Also, remove the .txt extension from the *ppc.txt files, and put those in the bin folder.
If you need any help getting it to work, or I forgot a step/file, I'd be glad to help.
http://zone.ni.com/devzone/cda/tut/p/id/5694
File Type: txt arppc.txt (61 Bytes, 27 views)
File Type: txt ccppc.txt (61 Bytes, 28 views)
Unread 13-01-2010, 09:07
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The easiest way to compile on linux is to use java.
Compiling Error DustinB_3 Programming 1 12-02-2007 18:06
Compiling problem Anime-niac_2.9 VEX 4 19-10-2006 16:13
Compiling Help!! ajsetter Programming 14 13-10-2005 10:38
compiling in linux dasRatsel Programming 1 21-05-2005 21:00
White Paper Discuss: IFI Loader for Linux with compiling instructions CD47-Bot Extra Discussion 1 09-02-2004 16:46
