Go to Post I've ridden the real Segway many times and I think it is a truly remarkable machine and worth every cent (if you have enough cents to spend on it). - sanddrag [more]
Unread 11-01-2010, 23:27
batmankiller batmankiller is offline
None #2601
batmankiller is an unknown quantity at this point
Dual languages possible on cRio?
I am new to robotics and our programming committee isn't that advanced as we had only one programmer last year and only starting to stock up and expand our school's resources this year. As usual we have disputes on whether to stick with Labview or use Java. My question is can the cRio compile and run both labview and java? say java for auto and labview for teleoperator? I'm thinking this wouldn't be possible since it would have to be in the same language to tell cRio when to switch to teleoperator, but if this is possible, please enlighten me.
Unread 11-01-2010, 23:58
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
Re: Dual languages possible on cRio?
In short, no this is not possible.
The cRIO's image is language specific because it has to load different libraries based upon each language, for instance the LabView libraries are different then the C++ libraries. This is why you have to choose a specific language to format your cRIO with when you image it.
Unread 12-01-2010, 00:20
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
However, if you wanted to try it, LabVIEW has something called a Code Interface Node, which allows you to call compiled code.
If you wanted to use compiled code for one of your modes, and LabVIEW for the hardware interface sections, you could.
The difficulty with Java is that it is also interpreted. (though it may be fully compiled for the cRIO, I don't know)
-- Marshal Horn
Unread 12-01-2010, 07:37
The Java for cRIO is not compiled. And unless your already know how to program the robot very well in both environments, I would not even try using the CLF node. It is a very advanced capability, and you are far better sticking with one tool until you really know what you are doing.
Greg McKaskle
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 23-04-2004 01:51
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
Other languages tchescow Website Design/Showcase 2 25-02-2003 11:28
Programming Languages Hailfire Programming 7 29-01-2003 21:10
