| View Poll Results: Should a robot be built to go over the bump or under the tower? | |||
| Over the bump |
150 | 81.52% |
| Under the tower |
34 | 18.48% |
| Voters: 184. You may not vote on this poll | |||
Re: Over the bump or under the tower
Over the bumps. Conquer them like they're flat!
The best answer is both. I don't see the tower and the bumps as being mutually exclusive.
While going through the tunnel may be faster, it is prone to blocking and any attempt at hanging is very very hard. Not to mention tunnels put even more size restrictions than the restrictions themselves.
My team is deciding that we don't WANT to go over bumps but if we HAVE to (in the event of an allied robot being disabled) you should BE ABLE TO. Our drive train will allow us to go over but we will ONLY if we have to.
For those designing to go under the tunnel, how are you dealing with the consequent visibility issues?
Is that actually a bad thing? If your opponents use two robots to shut down one, the rest of your alliance has a whole lot of field to work with. |
Thank you. Our team has decided that "Over the hills" is a much better way to reach Grandmother's house than to go "through the woods."
I hope that this thread helps other teams make thier decisions as well. A bit of information: based on our calculations assuming 6" wheels spread pretty much the farthest they could be, the CoG, if in the center, can be up to 36" high. p.s. We also decided to go with a mecanum drive, just in case you were interested. Last edited by quinxorin : 13-01-2010 at 22:20. |
Our team came to a similar conclusion. Also, if you plan to hang at the end, and you start in the zone not adjacent to the tower, you will have to cross a bump before hanging.
We came up with a little list at 1712, which is by no means complete, but i thought would be nice to share.
over pro quick can't be blocked con robot gets damaged risk of flipping if center of gravity isn't low can't control ball over under pro can control balls well low risk of damage con takes a while to line up to go under can easily be blocked risk of balls falling on you and getting stuck restricts robot size We decided to go with over as the initial strategy, but in order to get a low center of gravity we ended up building a chassis that could also fit under if we needed to. Kinda funny how things work out sometimes. I thought both was the best strategy, but would pick over if I had to pick just one. |
I'd say neither as well. I mean, why would you really need to traverse? Two robots aren't allowed in the opposing area and it seems that you'd probably need a robot manning all sections...
Traversing would probably only be necessary in a worst case scenario... |
#10
reminds me of the 2003 Stack Attack debate."Over the Ramp,or under the bar?"
#11
You know what they say about assuming things.... ![]() |
#13
We're strongly considering both, but I voted the tunnel option just so the battle looks a little less lopsided for this poll
I do not believe these options are mutually exclusive and as mentioned because of the ease in blocking tunnels it is almost a necessity that a tunnel bot can climb the bump as well. That said consider that defense played on you while crossing the bump may actually be worse, since an opponent hitting you as you come over is likely to cause a flip, the only advantage is that the bump provides much more room to try to avoid them on the other side. The tunnel is a good option for simplicity (though keeping a robot under 17" provides its own challenge) and it is significantly easier to move balls through the tunnel than the bump. Defense is easier to play on the platform but from a blocking position the opposing robot (depending on the zone) can do little other than continue to block (center field probably provides the worst shot to either goal in an alliance's home zone, and in the opponent's zone you can't defend many shots from the center either). Although easier I'm not convinced that blocking the tunnel will be very high on any alliance's priority list unless your robot can single-handedly outscore their entire alliance given the chance. Last edited by Donut : 12-01-2010 at 23:23. |
#14
Something to consider also is a robot low enough for the tunnel is a robot probably with a low enough CoG for the bump.
#15
Our team, after thinking about it, for a long time, came to the conclusion that the tunnel is a death trap. At any time an opposition robot can block
the entrance, block and/or jam itself in the inside, or you yourself could be trapped inside by opposition robots at both entrances. We'll be opting to figure out how best to cross over the bump. |
| Devils' Tower first rise under power! | Stu Bloom | Robot Showcase | 16 | 18-02-2005 11:20 |
| Q&A Discuss: How long is the bump from the ramp to the top? | CD47-Bot | Extra Discussion | 1 | 11-01-2003 09:48 |
| How long is the bump from the ramp to the top? | Tton | Rules/Strategy | 1 | 09-01-2003 18:26 |
| over/under the rail | archiver | 2001 | 8 | 24-06-2002 01:03 |
| Under or Over? To tank or Not to tank that tis the question! | archiver | 2001 | 2 | 23-06-2002 22:53 |
