Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Unread 07-10-2001, 17:38
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Additional allowed materials
We wish some clarification on which fasteners, bearings and swivels are legal, along with having a couple of other materials questions.
Question #1: The allowable additional materials state: "Fasteners: Unlimited [except ...]" and "Hinges, braces, brackets, (and other similar off-the-shelf support items): any size or amount."
Does the concept of "hinge" and "fastener" include ANY "off-the-shelf" hardware store swivels and/or load bearing JOINTED items that attach two things together with some numbers of degrees of freedom of motion?
If so, then IMHO it would seem that as long as an item attaches two things together, AND it is "off the shelf" at a local hardware store, it SHOULDN'T matter WHICH degrees of freedom of movement it allows. (However, I'd rather ask now during the design stage than find out later it is illegal. :-)
Examples of standard hardware store "N degree of freedom" fastening items we've already found and may wish to consider using which we'd like to clarify as to their legality:
A) A couple dollar Lazy Susan "hinge"
B) A cheap "ball and socket joint"
C) Pillar bearings for drive shafts to help protect the motors from excessive torque loads.
(If [C] is illegal, what ARE allowable or recommended "shaft bearing" constructions to protect the motors? This is our first contest, and want to make sure we don't screw up with something basic in our drivetrain construction... :-)
Question #2: The only adhesives stated in the additional materials list are Epoxy and Hot-Melt glue. Neither are a good choice for applying to sheet rubber, which is an allowed material. Can we use a rubber cement of some kind?
Question #3: The castors are "no mod". Can we buy a similar castor to cut up and use some of its pieces INSTEAD of the supplied one in our robot?
(This way can return the original one intact.)
Can we use additional similar castors?
Thanks!
- Keith McClary, Huron High Team #830
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Materials for traction parteyboy10 Rules/Strategy 1 13-01-2003 21:15
Additional hardware list archiver 2000 5 23-06-2002 22:54
additional materials: mylar? Frank Toussaint Off-Season Events 3 02-11-2001 16:06
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
Are additional pulleys "cable fasteners"? kmcclary Off-Season Events 6 26-10-2001 01:56
