Go to Post I hate that every year people turn this competition into whining rather than winning. - Akash Rastogi [more]
Unread 12-01-2010, 12:07
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Window Motor Modification - Is it legal?
Team 2219 is considering using a swerve drive this year, but our problem is where to mount the encoder on our steering motor. We are using the Window motors and right now our design does not leave any room for the encoder.
Our thought is that we can cut away part of the plastic housing on the Window Motor transmission where the other side of the output shaft is, drill a small hole, tap it and put in an assembly to mount the encoder.
Quoting the rules:
<R54> So that the maximum power level of every ROBOT is the same, motors and servos used on the ROBOT shall not be modified in any way
A. The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
My question is, does the opposite side of the output shaft still constitute an interface? Does modifying the plastic housing where the output shaft sits result in a violation of this rule? I will be posting this on the Q&A tomorrow but wanted to get your opinions first.
Thanks!
Window Motor Robo_Coyote Motors 5 21-01-2007 13:00
Globe motor modification Veselin Kolev Motors 11 26-01-2006 15:35
[OCCRA]: Motor shaft modification Alex Golec OCCRA Q&A 1 12-10-2005 21:39
Window Motor Calvin Motors 9 21-02-2005 17:04
Modification on the Torque motor? archiver 2001 0 23-06-2002 23:45
