Go to Post Defense will be everybody's part time job, not their career. - Wayne TenBrink [more]
Unread 12-01-2010, 13:45
Tank2010's Avatar
Tank2010 Tank2010 is offline
Draftsman. Ammoknights Rule!
AKA: Dave
FRC #1566 (Ammoknights)
Rookie Year: 2007
Tank2010 is an unknown quantity at this point
Mecanum Drive Train
We were wondering how other teams have connected the motors to the wheels. we have a couple of Ideas like using 4 tough boxes or just connecting the motors straight to the wheels. Any suggestions?
Team 1566 Rules!!!!!!!!
Unread 12-01-2010, 13:57
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: Mecanum Drive Train
Do not connect the output from the motor directly to the wheel. You will need to gear down the output from the motor to ensure the wheel has enough torque to move your robot and do so without popping every circuit breaker in the universe.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 12-01-2010, 13:59
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Take a look at the Toughbox Nano, it takes 1 motor and seems easy to mount direct drive.
Setting up a direct drive to your motors will end very poorly though, I would suggest you run some form of reduction at least. I also don't know if the CIM would react well to being loaded in that way. For our holonomic drive 2 years ago, we used direct drive toughboxes directly bolted to our frame (and it worked alright).
I would suggest making either a suspension for your chassis or making it out of a springy material, to ensure wheel contact at all times (will make control much easier).
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 12-01-2010, 14:00
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
You always want to have some sort of gearing between your motors and what they're driving. For a drive train, this almost always means a gear box of some sort. This helps to reduce the wear on your motors (because the shafts aren't placed under the strain that the shafts for the wheels or arms are placed under), making them last longer. Further, it allows you to chose how much torque/speed you want by changing the size of the gear reduction.
Unread 12-01-2010, 14:35
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
When 330 experimented with mecanums a few years back, they used the then-KOP gearbox (which was a design ancestor of the Toughbox) with one motor in each.
1135 used one-motor Toughboxes when they used mecanums in 2008.
Neither had issues with the gearboxes--and yes, they were bolted directly to the frame.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 12-01-2010, 14:39
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
we used banebot gearboxes on our linkage and had a mechanical linkage connect to plates bolted right to the gearboxes. The wheels were also direct drive off of them, and though we prepared for the stress to wear them out. They kept going, and still work today (2 seasons after) I love those gearboxes. Nice and small
Unread 12-01-2010, 14:48
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
810's using 4 BaneBots gear boxes, (same kind we were given in 2007).
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 12-01-2010, 16:45
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
FRC #0862 (Lightning Robotics)
quinxorin will become famous soon enough
My team, 862, used 4 individual CIMs with 4 toughboxes. I think we had a change in ratio via the chain too, but I cannot remember. I do remember that it most definitely needs to be geared down, however. That is especially the case if you plan to go over the bump.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 12-01-2010, 18:22
Tank2010's Avatar
AKA: Dave
Rookie Year: 2007
Thanx we were leaning toward having the 4 tough boxes like u all said to drive each wheel we were just unsure if there was another way to do it.
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
Mecanum Drive Train Sam2197 Technical Discussion 25 16-11-2008 20:51
Questions on Mecanum Drive Train charmed862 General Forum 3 09-01-2008 22:23
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
