Go to Post (pfft, kid... I sound like I'm Baker's age) - Amanda Morrison [more]
Unread 12-01-2010, 14:05
Team 1990 Team 1990 is offline
FRC #1990
Team 1990 is an unknown quantity at this point
Default code loading problems
Hello from team 1990,
I have been trying for two days to get the default program to work on our test bot. I have been able to update the classmate both driverstation and labview. I have been able to format the crio both wirelessly and through crossover cable connection. Labview acts as if the program is deploying yet nothing happend on the bot all lights 2 jaguars and green on sidecar, remain flashing. The drivers tation program says no code in the status screen. I have tried running the program in labview instead of deploy both with the run on right click and the arrow. Nothing seems to be effective. Any suggestions would be very welcome.
thanks,
Jim
Team 1990
Unread 12-01-2010, 15:34
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Default code loading problems
On the diagnostics tab of the driver station software, what does it say for the cRIO image?
Just to clarify, are you running LabVIEW on the classmate, or on your own computer? Make sure you updated LabVIEW on your own computer.
Unread 13-01-2010, 11:23
Freeztech's Avatar
Freeztech Freeztech is offline
FRC #0401 (Hokie Guard)
Team Role: Electrical
Freeztech is an unknown quantity at this point
Team 401 is having the same problem with the cRio. We believe its the communications VI, thanks to the work of our labveiw guru. but we still don't fully understand how they want us to load the code onto the cRio. we are currently using the 2010 control system. including the Classmate. we are currently using it with the crossover cable though.
Dubito, egro Cogito, egro sum.
Unread 15-01-2010, 19:58
bradleat bradleat is offline
FRC #1414
bradleat is an unknown quantity at this point
I get this same error with c++
Unread 15-01-2010, 21:57
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Question Re: Default code loading problems
I have seen this error in at least 10 other places and normally based on the error it means the c-RIO has not been reimaged to the most current version
for example v5 but ours is version v19 the most current version and we still get the error
i have ran through everything i know about lv (which is quite a bit) and found nothing
has anyone found anything?
p.s. both updates have been installed, the code is the default and the communication and stop button are green
Thanks
Problems running Default LabView Code Version 3.0 seg9585 Programming 6 01-02-2009 17:23
problems loading code with Easy C Clayton Programming 1 31-01-2008 15:15
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Problems with Kevin's 2007 default code bruss6 Programming 8 19-01-2007 15:42
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
