Go to Post I'm now convinced that the entire 2015 season was an elaborate ploy by FIRST to get teams to stop complaining about bumpers. - Joe G. [more]
Unread 12-01-2010, 17:55
star_lancer's Avatar
star_lancer star_lancer is offline
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
star_lancer is a jewel in the roughstar_lancer is a jewel in the roughstar_lancer is a jewel in the rough
Send a message via AIM to star_lancer Send a message via Yahoo to star_lancer
Holonomic Drive Help
Okay, I've got the basics for using holonomic drive and Omni-wheels. I can control the drive system with a joystick now. My problem is that I am unable to get the Gyro vi's and the Rotate to Target.vi to work with the new drive system. It's just really confusing for me. Could someone either show me an example of how the teleop would look with holonomic drive, or at least tell me how to get the Gyro .vi's and the Rotate to Target.vi to work with omni-wheels?
Pictures would be greatly appreciated.
If you found anything I said helpful, please click the scales next to my post. I really appreciate those reputation points.
Team 2346 - Build, test, panic, repeat.
Unread 01-02-2010, 21:30
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
Team Role: Teacher
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
Re: Holonomic Drive Help
Well, your are a step ahead of us :-) Would you mind posting a pic of your holonomic wiring in labview? Thanks! We've been working on it for two weeks and are having a lot of trouble.
~ Mr. Buonomo, Team 871
Unread 01-02-2010, 22:39
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by star_lancer View Post
...at least tell me how to get the Gyro .vi's and the Rotate to Target.vi to work with omni-wheels?
In the unmodified robot project, Rotate to Target provides a simulated X axis joystick signal into the X axis "rotate" input of an Arcade Drive vi. All you should need to do is replace that Arcade Drive with a Holonomic Drive, wiring to its "rotate" input instead.
quation Holonomic Drive use Windriver C++ yara92 C/C++ 3 01-01-2010 06:18
Holonomic drive and ramp robotaddict Technical Discussion 11 13-01-2006 16:57
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
Holonomic Drive Mathmatics Discussion robotaddict Programming 35 15-10-2005 13:29
Killough platforms (A.K.A Holonomic/kiwi drive) AK1 Programming 8 04-02-2005 21:36
