Go to Post How are we as mentors and coaches presenting ourselves? We we are is who they will emulate. It is the nature of coaching, the nature of leading. - MysterE [more]
Unread 12-01-2010, 22:26
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Team Role: Coach
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Problem with Default Program/Deploy
This was posted over in electrical, but I am having the same problem and hoping anyone in here might have some insight
"I have been trying for two days to get the default program to work on our test bot. I have been able to update the classmate both driverstation and labview. I have been able to format the crio both wirelessly and through crossover cable connection. Labview acts as if the program is deploying yet nothing happend on the bot all lights 2 jaguars and green on sidecar, remain flashing. The drivers tation program says no code in the status screen. I have tried running the program in labview instead of deploy both with the run on right click and the arrow. Nothing seems to be effective. Any suggestions would be very welcome."
Jeff Beltramo
Team #1922
Concord, New Hampshire
Help to Deploy a Program in Labview. Delian NI LabVIEW 7 10-12-2008 21:13
PWM Problem with Default Code kbregler Programming 16 03-02-2007 15:14
Problem with program uploading 1573 Programming 49 28-01-2007 13:51
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
