Go to Post One day the code will be written first, and then a robot built around it - dag0620 [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 13-01-2010, 08:23
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
Thumbs up Tired of Gray? Liven up that Pro/E Background!
Hi, it is the middle of winter and gray is not the most uplifting color, so why not change the background colors in Pro/E? If you want to use the same color scheme we have implemented for Pro/ENGINEER Wildfire 5.0, change your Top and Bottom blended background colors to these values:
- Top: 198, 220, 236
- Bottom: 92, 125, 169
To change these colors, choose View, Display Settings, System Colors... and then pick the Edit button for the Blended Background. This will bring up the Blended Color dialog box where you can assign any color to the Top and Bottom for the blend.
Experiment with some colors of you own
Unread 19-01-2010, 17:57
Swens's Avatar
Swens Swens is offline
AKA: Robert Swensen
FRC #2892 (Hottie Botties)
Team Role: Mechanical
Rookie Year: 2010
Swens can only hope to improve
Re: Tired of Gray? Liven up that Pro/E Background!
LOL!! Cool post but not entirely useful.
Unread 03-02-2010, 11:00
R1ffSurf3r R1ffSurf3r is offline
AKA: Charlie
FRC #0233 (The Pink Team)
Team Role: Driver
R1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to behold
i use pre-wildfire scheme
Unread 20-04-2010, 19:06
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
You may find that you change your system colors, then exit and re-launch Pro/E to find your colors missing! If this happens you may need to direct Pro/E to where your custom scheme is located.
Steps:
1. Set your custom scheme how you like it
2. In the System Colors menu, select file -> save. A good place to save this is in your Pro/E load point, along with your config.win and config.pro, this makes it very easy to track all of your custom Pro/E files and options, etc.
3. Go to Tools -> Options
4. Add the option "system_colors_file" and browse to the file you saved
Now each time you load Pro/E it will have your custom colors. You can also direct Pro/E to a number of files/directories this way, such as the symbols menu, drawing templates, etc, if your team has defined a custom set of these.
Rob
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Whats your opinion, Pro-life or Pro-Choice? efoote868 Chit-Chat 5 28-09-2007 10:11
Gray insulators, Din Rails HELP! fabbuki Electrical 2 19-02-2007 08:25
gray the snail nuggetsyl General Forum 2 13-03-2006 11:16
Tired of that booring old generic Windows loading screen? Psycho Penguin Chit-Chat 10 27-07-2005 19:24
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
