Go to Post Stop it with the "break the rules, just don't let anyone know" already! - Alan Anderson [more]
Unread 13-01-2010, 19:04
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Basic Robot Controls Not Working
We followed the steps to setup the new DS and when we try to run the 'FRC cRIO Robot Project' it runs but no motors move. The jaguar LEDs don't change the robot is enabled and all communications with the robot is fine.
The log files on the DS keep coming back saying something to the extent of
*"RobotDrive.lvlib:ArcadeDrive_Standard(NoSaturati on).vi>>Teleop.vi"*
We can run programs on the cRIO and get response but it is not running motors.
Update
We also get this error at the driver station.
An invalid set operation occurred, and the PWM channel was not allocated
Unread 13-01-2010, 20:32
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Rookie Year: 2007
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: Basic Robot Controls Not Working
Check to make sure you don't have a refNum in Begin.vi that is uses a already used PWM channel.
That's the only thing I can think of.
-Tanner
Robot not doing what we need it to, and printfs aren't working Bryan Herbst Programming 8 21-09-2008 20:58
Camera not working when connected to robot MarkVH Programming 5 14-02-2005 15:40
Camera not working when connected to robot MarkVH Programming 2 05-02-2005 18:08
Another team's robot signal not working zeep25 Control System 2 25-02-2004 23:33
Robot Controller Not Working !?!?! Team1425 Electrical 3 24-01-2004 20:52
