Articulating chassis???
Anybody thought about an articulating chassis? By that I mean one that bends in the middle so It goes over the bump without leaving the ground?
Any thoughts? Bruce |
Re: Articulating chassis???
it might be a good idea as long as the bumpers dont move... also it just seems like it might be more work then its worth
I'd like to see a sketch of what you have in mind.
Yeah, we though about it for a little while until we realized that the bumpers can't articulate. In my opinion, it would be pretty difficult and complicated to implement. But if you find a way to do it, I'm sure it would be pretty cool.
It can be done, but would it redefine where the bumper zone on your robot is located? If the back end, for example, drops below the front end (the front end is on top of the bump while the back end is on the ramp), the bumpers, while still between 10" and 16" above where the front wheels contact the top of the bump, are now possibly more than 16" above where the back wheels contact the ramp.
Thoughts? |
From page 4, section 8 The Robot:
You could have a suspension system with your wheels to accomplish the same thing, however. |
we threw this idea around a bit, and we so far see the most problem with the bumpers:
if the robot articulates in any way, even if it has a fixed frame to hold the bumpers, it would change the height of the bumpers and if they leave the bumper zone, that's illegal. you could perhaps design a system to hold the bumpers at the correct height at all times, but I'm thinking that's overkill considering that most "normal" robots should be fine just driving into bump slowly to get over it... |
Nope, nobody thought about that before. Except these folks:
http://www.chiefdelphi.com/forums/sh...ad.php?t=79951 http://www.chiefdelphi.com/forums/sh...ad.php?t=79737 http://www.chiefdelphi.com/forums/sh...ad.php?t=79931 http://www.chiefdelphi.com/forums/sh...ad.php?t=79832 http://www.chiefdelphi.com/forums/sh...ad.php?t=79910 |
BC |
#10
That could be a good question for the GDC. The problem comes with the definition of the bumper zone, from page 3 in section 8 The Robot:
What if the suspension is active?In that case, you may have an issue, as the suspension could push out, increasing the height of the bumpers outside of the bumper zone. What if the suspension is on all wheels? Then you might also have a problem, as any adjustment could cause your bumpers to leave the bumper zone. I would recommend asking the GDC about the legality of suspension on wheels and how that comes into affect with regards to traveling over the bump and the bumper zone before getting too far in your design process. |
#11
#12
Hi,
We are from team 3089. We are currently debating whether the following mechanical structure of the chassis and bumper is legal. The chassis is divided to two parts that are joined together allowing it to change its geometrical shape (as shown in the pictures) when going over the bumps (articulating chassis). Above the lower chassis, is a chassis of a larger perimeter that has a solid structure and will consist of the bumpers. As stated in rule <R11> the chassis itself does not change it's shape and when the robot moves on the flat surface it is parallel to the ground. But when the robot will go over the Bumps, the chassis changes it's angle compared to the ground and the robot. Regarding rule <R07> A, the upper chassis is designed so that the bumper will not go out of the bumper zone, and won't move or deform while on flat ground. Thanks, every comment is useful! |
| What exactly is "Articulating"? | Rion Atkinson | Rules/Strategy | 9 | 11-01-2010 19:32 |
| New AM C-Base Chassis vs. Old IFI KitBot Chassis? | ChuckDickerson | Kit & Additional Hardware | 5 | 06-01-2009 08:36 |
| 80/20 chassis | NorviewsVeteran | Technical Discussion | 30 | 04-01-2009 01:03 |
| Chassis | Torboticsmember | General Forum | 2 | 30-01-2008 16:30 |
| Chassis | ark_1230 | Technical Discussion | 2 | 04-09-2002 22:51 |
