Go to Post The 2006 FRC Manual: Read it. Learn it. Know it. - dlavery [more]
Unread 17-01-2010, 14:55
TEntwistle's Avatar
TEntwistle TEntwistle is online now
AKA: Trey Entwistle
FRC #0433 (Firebirds)
TEntwistle is just really niceTEntwistle is just really niceTEntwistle is just really niceTEntwistle is just really nice
Re: Video of Kicker Prototypes
Originally Posted by Bill_B View Post
Great GP/sharing for this video! Gotta watch the "air" under the ball though. If you get one outside the field (over the railing OR end zone) it'll be a serious penalty. yellow card?
My read of the rules is that you only get a yellow card for an intentional shot of the ball outside of the arena
It is sometimes better to be lucky than good.
Unread 17-01-2010, 11:50
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Team Role: Teacher
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Originally Posted by ttldomination View Post
I'm sorry but I do not quite understand the first method. Is the piston pressurized, and then you guys pull against the pressure causing it to kick out?
I share in ttldomination's confusion. It looks like you're using the compressed air in the cylinder as the stored energy. What's missing is the device that compresses the cylinder, releasing it when you want to fire.
Has anyone considered using a small bore cylinder (and thus fast extension) to push a lever near its fulcrum? Or would the small cylinder be unable to provide the "oomph" necessary?
"It's NOT Just A Robot Thing!"
Unread 17-01-2010, 12:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
To figure out roughly how big of a cylinder you need based on how much "oomph" you need, figure out how much energy the ball needs as it begins it's trajectory..then figure out how much energy you can get into a cylinder. You only have 60 psi and max 2" bore to work with.
Unread 18-01-2010, 04:06
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
The big issue with air cylinders is that a good kick needs to place an object going at ~25-30 MPH in contact with the ball for about 1/50th of a second with said object having enough momentum that it doesn't lose too much speed during contact with the ball.
Pneumatic pistons have to drive the air in front of them out of the cylinder as they accelerate within it. This often restricts their peak velocity, depending on the orifice size of the cylinder's air exit hole. I don't know if it is allowed, but pulling a vacuum on the cylinder ahead of the piston would effectively give a 15LB pressure boost and seriously increase peak piston speed.
The CFPM capacity of the KOP air compressor also seems much too low to allow very many high power shots. Perhaps using a motor to drive a piston back into a sealed cylinder to built up the air pressure inside to the legal max would allow for both more frequent and stronger shots to be taken in a match.
-RRLedford
Last edited by RRLedford : 18-01-2010 at 04:10. Reason: non-swear verb was flagged/blocked as swearing noun.
Unread 18-01-2010, 04:25
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Originally Posted by GaryVoshol View Post
There was a robot that had a rapid fire and reload mechanism for shooting balls. It must have been for Aim High. It used a cam arrangement to pull the latex tubing back into tension. Anyone remember it?
It seems something like that, with a pause before firing because we aren't rapid loading this year, would pull the kicker back into the FRAME PERIMETER within the 2 second limit.
I know which robot you're talking about and remember the video vividly, but also cant remember which team no. It was the most unorthodox shooter, yet effective and accurate of all the '06 bots I saw that year.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 18-01-2010, 18:23
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Was it 1523?
http://www.youtube.com/watch?v=i91FrxBT10o
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 18-01-2010, 21:15
Bigjsp Bigjsp is offline
1st time mentor, old hotrodder
FRC #3324 (Metrobots)
Team Role: Operator
Rookie Year: 2010
Bigjsp is an unknown quantity at this point
We tried hitting the ball directly with several different sized pneumatic 3/4, 1, 1 1/8, 2 (4-6 inch strokes) and even a 3" diameter 1" stroke cylinders, which all seemed compatible with the volume of air storage allowed.
Under the best case, the ball had enough energy to roll the distance but not really enough to clear multiple ramps.
On dual acting cylinders we had the exit port wide open to be the best case.
We have a neat kicker concept but the pneumatics just wouldn't support it.
Unread 18-01-2010, 21:24
spaztec's Avatar
spaztec spaztec is offline
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
Team Role: Electrical
spaztec is an unknown quantity at this point
Send a message via AIM to spaztec
looking good
2007 Boston Regional Champion
2005 California Regional Champion
2005 Connecticut Regional Champion
2004 California Regional Champion
2004 NH Regional Regional Champion
2002 Connecticut Regional Champion
2001 Connecticut Regional Champion
Team 1646 Shooter Prototypes Video Ryan Dognaux Robot Showcase 31 25-01-2009 01:17
pic: Team 1501's shooter...errr kicker Wayne Doenges Robot Showcase 9 14-02-2006 14:44
how are those prototypes coming? Solace General Forum 14 18-01-2004 22:19
Watch us build prototypes Joe Canavan General Forum 1 13-01-2002 18:19
