Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. - Yipyapper [more]
Unread 14-01-2010, 16:52
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
Rookie Year: 2007
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
Grabbing Output from Robot Sensors
We're trying to connect the Classmate, Dev Laptop, and Robot so we can get feedback from our sensors in WindRiver C++.
We've connected it with a setup like this: dev laptop and classmate to router, which wirelessly connects to the robot. We've also tried hooking everything up directly to an ethernet switch. Still don't work.
When we try to connect with the console, the Classmate intermittently displays "Watchdog Not Fed". The robot reaction works, but is delayed when we try the drives. The output on the console has all 0 values. Without the Dev Laptop in this network, the robot works fine.
We fed, disabled, and even tried to kill Watchdog. We've tried different laptops. It still does not work.
-1951-44U
Unread 14-01-2010, 17:16
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: Grabbing Output from Robot Sensors
The Watchdog not fed message means that the running program enabled the watchdog timer and is not calling the Feed() method before the expiration time runs out. If you have autonomous code that does a long Wait() you are probably running out the watchdog timer. If you have a program loop in your teleop code then you might be missing a call to Feed().
The configuration of the programming laptop and driver station shouldn't matter if they are all successfully talking to the robot.
Are you running some sample code or your own program?
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 14-01-2010, 22:17
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Rookie Year: 2007
We are using our own code. There are no loops in our teleop, and we haven't used the autonomous yet. We had GetWatchdog().Feed() 's all over the teleop when we were trying to feed the watchdog.
Unread 15-01-2010, 03:06
ranc ranc is offline
FRC #2489
ranc is an unknown quantity at this point
Wait you have no while(true) or while(IsOperatorControl()) loops?
I remember leaving out said while loop and getting the same issue.
Unread 15-01-2010, 09:41
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Rookie Year: 2007
Well, we have those loops, but we have no others. We have Feed()'s within those loops, too.
Does the line "GetWatchdog().SetExpiration(0.1);" in the initializers do anything? Can I delete this?
Unread 15-01-2010, 10:59
AKA: Brad
That sets the expiration time of the watchdog timer. That means that it must be fed within 0.1 second (100 milliseconds) before it times out and the motors stop with the "Watchdog not fed" error message.
If there are any Wait() calls in your loop that are greater than 100ms, the the watchtog will also time out.
Brad Miller
Unread 15-01-2010, 15:41
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Rookie Year: 2007
Can I SetExpiration at some ridiculously high number to get rid of the watchdog error?
Unread 15-01-2010, 16:22
FRC #2489
You could use GetWatchdog().SetEnabled(0) for turning it off right before your long wait and then use GetWatchdog().SetEnabled(1) for turning it back on again when you're not initializing whatever you're initializing (i'm assuming your long wait is due to setup of some component)
Unread 15-01-2010, 20:12
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Rookie Year: 2007
I'll try that tomorrow. But I haven't a single Wait() in the program. ._.
Can I completely delete the GetWatchdog().SetExpiration() or completely replace it with the .SetEnabled()?
Unread 15-01-2010, 23:46
FRC #2489
Yes I think you could just use set enabled to turn it off
Unread 16-01-2010, 12:25
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Rookie Year: 2007
We tried setting the Watchdog at SetEnabled(0), but still get the same problem. We set it at 0 in the initializers, in autonomous, in the operator function, and in the operator loop. Setting SetExpiration() at an impossibly high number had no success, either.
Problem receiving console output from cRIO Arborama Programming 7 15-02-2009 03:30
Weird output from ultrasonic and gyro Yuan Xue Lim Programming 4 11-02-2009 19:01
live input/output to/from application MarkH Programming 3 06-04-2006 01:43
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
output from a cell phone? Ben.V.293 Electrical 6 24-12-2003 14:52
