Go to Post [the last period is] a free for all, both goals are turned on, and any robot can go anywhere on the field and score in any goal (although I would recommend scoring in the correct goal, not your opponents :D ) - Ryan Foley [more]
Unread 14-01-2010, 17:18
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Mecanum drive question (Square configuraton?)
So, I have searched through and read alot about the different types of omni directional drive trains, and we have decided that mecanum fits our team best.
I have one question about the orientation of the wheels though. For the wheels to work correctly andmark describes that they need to form an x pattern.
Although, It does not state that the width and length between the center of the wheels needs to be a square. Some of the kids on our team think that it does need to be in a square.
Can anyone confirm that the wheels need to be aligned in a square fasion?
Unread 14-01-2010, 17:32
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: Mecanum drive question (Square configuraton?)
Don't confuse mecanum with holonomic. Holonomic drives use omni wheels in an x pattern and work best in a symetric layout. Mecanum drives use wheels with rollers at 45 deg to the plane of rotation and don't need to be x'ed. Both drive systems use one motor/gearbox per wheel.
Unread 14-01-2010, 17:36
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
Here: http://lib.store.yahoo.net/lib/yhst-...lSpecSheet.pdf
It describes the wheels as being in an X.
What I'm curious is, does the x need to be a square x?
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
They can be in either a
/ \ or an X.
I can confirm a rectangle works fine; our robot is a rectangle and our mecanums work fantastically. I don't know about trapezoidal shapes though...
Team Leader
Team 1595
Last edited by willson.thomas : 14-01-2010 at 17:37. Reason: Shape came out wrong.
Unread 14-01-2010, 17:37
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
Rookie Year: 2007
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Mecanum wheels should be installed the same as a tank drive system. The x pattern applies to the direction that the rollers face as far as I know.
Unread 14-01-2010, 18:04
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Mecanums do not have to be in a square pattern (wheelbase), though it may help turning to have that.
The rollers may form either an X or an O; this may be judged based on contact pattern or on looking at the top view (which is the opposite of the contact pattern). The good news is that if you don't like one pattern, change the wheels end-for-end and you get the other one in maybe 15-20 minutes of work. Just make sure that you've got either an X or an O, or your sliding will be off...
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-01-2010, 18:18
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Eric's got it, but I heard that if you have an "O" from a top view you won't be able to rotate.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 14-01-2010, 18:58
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
Thanks! This helped us out a lot today.
Unread 14-01-2010, 19:04
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Rookie Year: 1997
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Mechanums will ONLY work in ONE configuration That I have found.
The frame can be either square or rectangular... that doesn't matter.
BUT there is only one way the wheels can be oriented and work properly
Look at the AXLES from the top they have to be in the X configuration as in
Which means if you flip it over and look at the Axles... (or if you were looking up at the bottom and the bot was on a piece of glass over you)... the AXLES must form an O as in
NO OTHER CONFIGURATION SEEMS TO WORK. Not sure why. Good luck at the game!
Steve
Unread 14-01-2010, 19:30
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
Rookie Year: 2007
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Originally Posted by Steve_Alaniz View Post
Mechanums will ONLY work in ONE configuration.
BUT there is only one way the wheels can be oriented and work properly (and I can prove this)
NO OTHER CONFIGURATION WILL WORK. Same yourself all the time I wasted... Believe it. And good luck at the game!
Steve
I would have to agree. I haven't actually used mechanum before, but the theory holds up better on the "O" pattern. Basically, if you look at the roller from the bottom, it should be able to slide diagonally. The "X" is from the top. If the "X" were on the bottom, there would be absolutely no way to slide diagonally. Only forward/backward or only side to side would work, and I think rotating would feel pretty normal, but generally, holonomic drive trains are best when you're able to use them point-and-shoot (including diagonals).
By the way, for anyone confused as to why I used "holonomic," it's because it's a description of the movement of the drive train, not the way you accomplish it. Omniwheel drive (kiwi, 4-wheel omni), mechanum, and swerve drive are all types of holonomic. Basically, it means that the controllable degrees of freedom are equal to the total degrees of freedom on that plane. Since our robots drive on a two-dimensional plane (hopefully), there are 3 degrees of freedom; X, Y, and ω (omega, yaw, or rotation). Some advanced helicopters can be holonomic because they can control all 6 degrees of freedom on the 3 dimensional; X, Y, Z, roll, pitch, yaw. Fun Fysics Fact of the day.
Unread 14-01-2010, 21:01
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
We have Mecanum's and they have to be in an X looking down from the top or you loose maneuverability (I think either zero turn radius or strafing). Also, keep in mind that mecanum's have very little pushing power so if you plan to use these wheels your drivers better practice so that they don't get pushed and pinned.
Conceptually, you can think of mecanums as having two vectors, here is a very good PDF on drive systems
http://www.firstroboticscanada.org/s...irectional.pdf
Unread 14-01-2010, 21:10
Rookie Year: 1997
Thank you for that observation! I believe you are right. The other configuration appears to cause a conflict in rotation. I KNEW there was some reason I only use the X on top method.
Steve
Unread 14-01-2010, 21:45
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Would anyone know if there is a difference in the X vs O pattern in terms of if you hit the bump on a slight angle?
For some reason, it makes sense to me that one orientation of wheels would help the front end of the robot correct itself, whereas the other orientation would actually HELP your robot to roll off right the bump.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 14-01-2010, 22:43
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Mr. Lim View Post
Would anyone know if there is a difference in the X vs O pattern.
Do not make the assumption that an O pattern (viewed from above) will work. Only the X pattern (viewed from above) should be used.
  #15   Spotlight this post!
Unread 14-01-2010, 22:50
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
You DON'T want an O pattern when looking down at the top of your robot unless you want to lose the ability to spin in place. Only X pattern (top down) configurations will have turn in place ability, unless you significantly tighten your rollers.
The reason is fairly simple. Wheels can only exert force in a direction they don't slip in. If you think about a standard omni-wheel, you'll realize this. It can only push front to back, not side to side. Which makes it easy to turn and easy to push sideways.
Mecanum wheels have axles that are angled 45 deg from the direction of the wheel. This means they slip in one diagonal direction, and push in the direction of the axle that's touching the ground.
So you have a choice, all the axles pointing at the center of your robot, pushing into/out from the center of your robot (O-style), or all the axles pointing perpendicular to the center of your robot, pushing at right angles to your robot (X-style).
So, grab 4 students, put each on a corner of your robot and ask them to push on their corner to turn the robot in place. They're going to push their corner sideways, at right angles to the center, like the X-style. If you ask them to turn the robot by all of them pushing towards the center of the robot (O-style) they're probably going to give you funny looks and go find some screws to sort.
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Mecanum Drive - Help Smoking_Gun Programming 22 04-12-2007 20:51
Mecanum Drive Technique Dan Petrovic Technical Discussion 9 16-08-2006 20:42
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
