Go to Post This is high school robotics for fun and education. Let's try and keep it that way. - Rod [more]
Unread 14-01-2010, 19:56
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Saitek X52 Joystick Compatibility
Our team recently received a new control joystick, the Saitek X52, which includes about 20 buttons, 3 modes, and 3 extra axis.
Would it be possible to enable control over the whole joystick, or are we restricted by the LabVIEW library, which only supports 12 buttons and no extra axis?
Unread 14-01-2010, 20:06
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Saitek X52 Joystick Compatibility
During the beta test, we tested a Saitek Cyborg X. It had 6 axis and 13 buttons. The last button did not work. It's limited by the communication protocol between the driver station and the robot controller (ie you have the same limitation in C++ and Java).
Our joystick did come with software that allowed to you remap the axis and buttons, so that you can choose which buttons and axis to use.
2005 Compatibility NinJA999 Control System 1 19-01-2008 17:37
Vista compatibility? EHaskins Programming 29 19-03-2007 11:22
Saitek X52 Flight Control System Arkorobotics Programming 2 23-01-2007 18:34
Pneumatics compatibility archiver 2000 4 23-06-2002 22:54
AutoCad compatibility archiver 2000 4 23-06-2002 22:51
