Go to Post If the refs are not calling something that you think should be called, you have to adjust your play style to deal with it. - Rob [more]
Unread 14-01-2010, 22:15
DuskProgrammer DuskProgrammer is offline
FRC #2421
DuskProgrammer is an unknown quantity at this point
Swerve Drive
This year my team is thinking of using swerve drive for the first time. We are planning to use the ones off AndyMark since we can't make our own.
http://andymark.biz/swervemodules.html
However, since this will be our first time (if we use it), I don't know much about how to program it. I would appreciate help in knowing if I need to get any other sensors for it. Additionally (and the main reason I'm posting it here), I would like some help in figuring out how to program it in Java/C++.
I would like sample code if you can provide, as well as different ways I can implant the driving while trying to keep it simple enough that the drivers can figure out how to drive it.
Thanks.
Swerve Drive Team1710 Technical Discussion 11 07-03-2009 09:58
Swerve drive 4, 2+2? kirtar Technical Discussion 18 02-04-2008 06:58
A Swerve Drive Question lndnny Technical Discussion 10 20-07-2006 08:09
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
