Go to Post Honestly I'm looking forward to just seeing all my friends again, that's what FIRST is really about to me. - Barry Bonzack [more]
Unread 15-01-2010, 12:14
megaman295 megaman295 is offline
FTC #3735
megaman295 is an unknown quantity at this point
[FTC]: HELP! Building a Catapult
Hi. Our team is trying to build an efficient, powerful, and consistent catapult, but so far we have not thought of a good way to build a good catapult and a good program for it. Can anybody give us tips on building the catapult and making a good program for it? We only have the initial kit so far, so if it needs any extra pieces, list these.
Unread 15-01-2010, 14:42
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Re: [FTC]: HELP! Building a Catapult
This video might provide some inspiration: http://www.youtube.com/watch?v=qLqPGVd5o9I
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 17-01-2010, 09:45
FTC #3735
Cool! Do you think it could still work even if we aren't using VEX?
Unread 19-01-2010, 07:52
Tony Allen Tony Allen is offline
TETRIX Product Manager
Rookie Year: 2007
Tony Allen will become famous soon enough
Try this video.
http://www.youtube.com/watch?v=VcrOkCY9JQY
Unread 19-01-2010, 21:48
Connor's Avatar
Connor Connor is offline
FTC #3768 (Crusading Cucumbers)
Team Role: Leadership
Connor is an unknown quantity at this point
It should still be able to work. I believe we can use rubber bands. Also my team designed a different catapult earlier in the season. I dont have a video, but i can try to describe it. The arm of it was two to three layers of polycarbonate fastened together then fastened at a base. There a small scoop at the top to hold a ball. String was tied to the top which was attached to a motor (use diferent parts attached to the motor to increase pulling speeds). A servo motor was then used to hold the catapult in place at the bottom as the string was loosened. When the servo released, the ball went flying. I dont know the coding for it, I am not the one who programmed it, but it should be fairly simple. Its a good design but catapults are slow and can only shoot one ball at a time. Just a word of advise. Hope this was some help,
"Never is just reven spelled backwards."
Unread 20-01-2010, 21:37
ejak0 ejak0 is offline
FTC #3595
ejak0 is an unknown quantity at this point
I believe there was a pretty decent catapult at the Seattle competition that used surgical tubing as the force generator which was attached to a long piece of channel with some sort of bin at the top. It then had a winching mechanism to reset.
Not that helpful, I know. But maybe.
Unread 21-01-2010, 20:48
Rookie Year: 2007
Here is a catapult using the TETRIX building system
Unread 22-01-2010, 17:13
danholl danholl is offline
Dan Hollands
FTC #0796 (Harley Wolves)
Team Role: Coach
danholl is an unknown quantity at this point
We made an arm that whacks the ball instead of trying to catapult it
On youtube check our videos for danholl3 to see it in action
Key is to always have the whacking arm start at the same location.
Are staples aloud with the building of the FTC robot? Connor General Forum 2 07-01-2010 17:40
[FTC]: Building Low Cost Playing Field Christine3491 FIRST Tech Challenge 1 26-09-2009 08:57
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: [FTC]: HELP! Multiple fields set up!!! galewind FIRST Tech Challenge 10 16-12-2007 09:53
Catapult Programing Help MRClark Programming 3 02-12-2007 16:07
